Type with comfort and convenience using a Samsung AA-SK1PWUB wireless keyboard. Don't worry about running out of power unexpectedly - battery status is displayed using a handy built-in LED indicator. It's also easy to control functions like volume, mute, and sleep mode with the touch of a button. As well as having great features and wireless performance, typing is a pleasure with attractive and ergonomic pantographic keyboard design. So, discover the wireless typing and increase your productivity.
Type anywhere with wireless keyboard
Enjoy total control from virtually anywhere in the room. With 2.4 GHz RF wireless keyboard, you can get the freedom and convenience of typing. Also, boasting a beautiful transparent finish, this keyboard gives every Samsung computer an instant upgrade. -
Keep an eye on performance
The keyboard features LED lights that indicate the current state of the caps lock and battery life, so it's easy to see what's happening at a glance. Plus special keys provide one-touch access to a variety of useful features - volume, mute, and sleep - so you can quickly control and optimize settings. -
Pantograph keys for comfortable typing
Enjoy the perfect keystroke with a pantograph keyboard that enables fast and accurate typing, regardless of where the keys are located. The low-profile, isolated keys provide a crisp and responsive feel, with optimized spacing for maximum comfort. It's also cleaner and much more hygienic as dirt cannot be trapped between the keys.
- Samsung AA-SK1PWUB - keyboard
- Keyboard
- Interface
- 2.4 GHz
- Wireless Receiver
- USB wireless receiver
- Connectivity Technology
- Wireless
- Keys Qty
- 106
- Hot Keys Function
- Sleep, volume, mute
- Pantograph key structure, battery LED indicator
- 44.2 cm x 13.8 cm x 2.1 cm
- Designed For
- ATIV Smart PC, Smart PC 500T, Smart PC Pro, Smart PC Pro 700T; Chromebook Series 5; N145; N145 Plus; NC110; NC215; NF210; Q330; Q430; Q530; QX411; R540; R730; RC512; RC512I; RF511; RF711; RV510; RV515; RV520; RV720; Series 2; 3; 4; 5; 6; 7; 7 Chronos; 9; SF410; SF411; SF511
- Keyboard
- Interface
- 2.4 GHz
- Max Operating Distance
- Up to 8 m
- Wireless Receiver
Input Device
- Wireless
- Keys Qty
- 106
- Hot Keys Function
- 44.2 cm
- 13.8 cm
- 2.1 cm
- Designed For
- Samsung ATIV Smart PC, Smart PC 500T, Smart PC Pro, Smart PC Pro 700T , Samsung Chromebook Series 5 XE500C21 , Samsung N145 , Samsung N145 Plus , Samsung NC110 , Samsung NC215 , Samsung NF210 , Samsung Q330 , Samsung Q430 , Samsung Q530 , Samsung QX411 , Samsung R540 , Samsung R730 , Samsung RC512 , Samsung RC512I , Samsung RF511 , Samsung RF711 , Samsung RV510 , Samsung RV515 , Samsung RV520 , Samsung RV720 , Samsung Series 2 200B4A A01, 200B4A A02 , Samsung Series 3 , Samsung Series 4 400B2B, 400B2B A01, 400B2B A04, 400B2B H01, 400B4B, 400B4B A01, 400B4B H01, 400B4B S01, 400B4BI, 400B4C A01, 400B5C A03, 400B5C A04, 400B5C-A01, 400B5C-A02, 410B2B A02 , Samsung Series 5 , Samsung Series 6 600B5B, 600B5BH, 600B5B-HC1, 600B5B-S01, 600B5B-S02 , Samsung Series 7 , Samsung Series 7 Chronos 700Z3AH, 700Z3A-S01, 700Z3A-S02, 700Z3A-S03, 700Z3C, 700Z3CH, 700Z3C-S05, 700Z5A, 700Z5AH, 700Z5A-S01, 700Z5A-S02, 700Z5A-S03, 700Z5A-S04, 700Z5A-S05, 700Z5A-S06 , Samsung Series 9 , Samsung SF410 , Samsung SF411 , Samsung SF511
