Samsung Wireless Adaptor with Passive NFC (M4583FX & M4580FX)
Quicklinx: B2ZCWS00 Mfr#: SL-NWE001X/SEE
  • IEEE 802.11n
Enable your printer or MFP to join your Wi-Fi network for improved workflow opportunities. Active Near Field Communication (NFC) allows you to easily connect a smartphone or tablet to the device via Wi-Fi or Wi-Fi Direct by simply tapping in. The added feature of secure print authentication will help to ensure that sensitive documents are protected from unauthorized use.
Samsung SL-NWE001X - print server
Print server
External
5.5 cm x 20.5 cm x 14.5 cm
170 g
802.11b/g/n, NFC
MultiXpress X4220RX, X4250LX, X4300LX, X7400GX, X7400LX, X7500GX, X7500LX, X7600GX, X7600LX; ProXpress C2680FX, M4530ND, M4580FX, M4583FX
Print server
External
Wireless
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, NFC
5.5 cm
20.5 cm
14.5 cm
170 g
Samsung MultiXpress X4220RX, X4250LX, X4300LX, X7400GX, X7400LX, X7500GX, X7500LX, X7600GX, X7600LX , Samsung ProXpress C2680FX, M4530ND, M4580FX, M4583FX
