Enable your printer or MFP to join your Wi-Fi network for improved workflow opportunities. Active Near Field Communication (NFC) allows you to easily connect a smartphone or tablet to the device via Wi-Fi or Wi-Fi Direct by simply tapping in. The added feature of secure print authentication will help to ensure that sensitive documents are protected from unauthorized use.
- Samsung SL-NWE001X - print server
- Print server
- Form Factor
- External
- 5.5 cm x 20.5 cm x 14.5 cm
- 170 g
- Data Link Protocol
- 802.11b/g/n, NFC
- Designed For
- MultiXpress X4220RX, X4250LX, X4300LX, X7400GX, X7400LX, X7500GX, X7500LX, X7600GX, X7600LX; ProXpress C2680FX, M4530ND, M4580FX, M4583FX
- Print server
- Form Factor
- External
- Connectivity Technology
- Wireless
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, NFC
- 5.5 cm
- 20.5 cm
- 14.5 cm
- 170 g
- Designed For
- Samsung MultiXpress X4220RX, X4250LX, X4300LX, X7400GX, X7400LX, X7500GX, X7500LX, X7600GX, X7600LX , Samsung ProXpress C2680FX, M4530ND, M4580FX, M4583FX
