The Samsung ViewFinity S9 redefines the standards of visual and functional design in professional monitors. With its expansive 49-inch curved screen and Dual Quad HD resolution, it offers an immersive viewing experience. The monitor's impressive color accuracy, covering 125% sRGB and 95% Adobe RGB, makes it ideal for professionals in photography, video editing, and design.
Beyond its visual capabilities, the Samsung ViewFinity S9 stands out for its advanced connectivity options. A built-in KVM switch, USB 3.0/USB-C hub, and USB Power Delivery up to 90 watts allow for a clean, efficient workspace by connecting and charging multiple devices through the monitor. Ergonomic features like height, swivel, and tilt adjustments, along with Eye Saver Mode and Flicker-Free technology, ensure comfort during long hours of work.
For those seeking a monitor that combines performance with exceptional comfort and connectivity, the Samsung ViewFinity S9 is the choice. Its suite of features, including HDR400 certification and specialized modes for gaming and productivity, make it a versatile tool for any task.
- Samsung ViewFinity S9 S49A950UIP - S95UA Series - QLED monitor - curved - 49" - HDR
- QLED monitor - 49"
- Energy Class
- Class G
- Energy Consumption per Year
- 66 kWh
- Curved Screen
- KVM Switch, USB 3.0/USB-C hub, USB PD 90 Watt
- Panel Type
- VA
- Aspect Ratio
- 32:9
- Native Resolution
- Dual Quad HD 5120 x 1440 at 120 Hz
- Brightness
- 400 cd/m²
- Contrast Ratio
- 3000:1
- HDR Capable
- DisplayHDR 400
- Response Time
- 4 ms (grey-to-grey)
- Colour Support
- 1.07 billion colours
- Colour Gamut
- 125% sRGB, 88% NTSC, 95% Adobe RGB, 95% DCI-P3
- Input Connectors
- 2xHDMI, DisplayPort, USB-C
- Built-in Ethernet
- Height, swivel, tilt
- Voltage
- AC 100-240 V
- Charcoal black
- 119.95 cm x 34.97 cm x 52.31 cm
- 14.6 kg
- Display Type
- QLED monitor / TFT active matrix
- Energy Class
- Class G
- Energy Class (HDR)
- Class G
- 66 kWh
- Diagonal Size
- 49"
- Curved Screen
- Yes (1800R)
- Built-in Devices
- USB Power Delivery
- 90 Watt
- Panel Type
- VA
- Aspect Ratio
- 32:9
- Native Resolution
- Brightness
- 400 cd/m²
- Contrast Ratio
- 3000:1
- HDR Certification
- DisplayHDR 400
- Colour Support
- Colour Gamut
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Picture by picture, Cinema Mode, Mega Dynamic Contrast Ratio, Black eQualizer, CustomColor Mode, FPS Mode, Flicker Free technology, RTS Mode, Image Size, Factory Calibration, Eco Saving Plus, Eye Saver Mode, Off Timer Plus, Low Input Lag, Quantum Dot Technology, Screen Size Optimizer, Refresh Rate Optimizer, RPG Mode, AOS Mode, sRGB Mode, Dynamic Contrast Mode, High Bright mode, Auto Source Switch, ergonomic stand, 3-side virtually borderless design
- Charcoal black
- 119.95 cm x 34.97 cm x 52.31 cm - with stand
- 14.6 kg
Audio
- Speakers
- DisplayPort 1.4 , 2 x HDMI , Network (RJ-45) , USB-C (power up to 90W) , 3 x USB 3.0
Mechanical
- Tilt Angle
- -2/+15
- Swivel Angle
- 30
- Height Adjustment
- 120 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x HDMI cable , 1 x USB-C cable
- Input Voltage
- AC 100-240 V
- Power Consumption (Typical)
- 45 Watt
- Power Consumption (Max)
- 220 Watt
- Power Consumption Stand by
- 0.5 Watt
- 0.3 Watt
- Dimensions & Weight Details
- With stand - width: 119.95 cm - depth: 34.97 cm - height: 52.31 cm - weight: 14.6 kg , Without stand - width: 119.95 cm - depth: 19.37 cm - height: 36.94 cm - weight: 11.6 kg
- Shipping Width
- 132.7 cm
- Shipping Depth
- 31.8 cm
- Shipping Height
- 49.7 cm
- Shipping Weight
- 20.1 kg
- 10 °C
- 40 °C
- 10 - 80% (non-condensing)
