Experience a visual world with the Samsung ViewFinity S7 32-inch monitor, designed for desktop use. With a 3840 x 2160 native resolution, this monitor delivers clarity and detail, perfect for work and entertainment. The 350 cd/m² brightness ensures vivid images, while the 3000:1 contrast ratio enhances the depth and richness of colors. With a viewing angle of 178 degrees both horizontally and vertically, every angle offers an immersive experience without distortion.
Enjoy features like Picture-in-Picture and Picture by Picture to boost productivity, along with Flicker-Free technology and Eye Saver Mode to reduce eye strain during long usage. The monitor's adaptive picture adjusts brightness and contrast according to on-screen content, maximizing your experience. With a variety of connectivity options, including HDMI and DisplayPort, the Samsung ViewFinity S7 fits seamlessly into any setup, whether for gaming, graphic design, or video editing.
- Samsung ViewFinity S7 S32D701EAU - S70D Series - LED monitor - 32" - HDR
- LED-backlit LCD monitor - 32"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/1965515
- Energy Class
- Class F
- Energy Consumption per Year
- 45 kWh
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- UHD 3840 x 2160 at 60 Hz
- Brightness
- 350 cd/m²
- Contrast Ratio
- 3000:1
- HDR Capable
- HDR10
- Response Time
- 5 ms
- Colour Support
- 1.07 billion colours
- Colour Gamut
- 99% sRGB
- Input Connectors
- HDMI, DisplayPort
- Tilt
- Voltage
- AC 100-240 V
- Warm white
- 71.39 cm x 18 cm x 50.16 cm
- 5.9 kg
- Environmental Standards
- TCO Certified Displays 9, TCO Certified, generation 10, for displays
- TUV Rheinland Intelligent Eye Care Certification
- Display Type
- Energy Class
- Class F
- Energy Class (HDR)
- Class G
- 45 kWh
- Diagonal Size
- 32"
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 350 cd/m²
- Contrast Ratio
- 3000:1
- HDR Format
- HDR10
- Colour Support
- Colour Gamut
- 99% sRGB
- Response Time
- 5 ms
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Picture by picture, Flicker Free technology, Image Size, Eye Saver Mode, Factory Tunning, Off Timer Plus, Picture-in-Picture, Auto Source Switch+, Adaptive Picture
- Warm white
- 71.39 cm x 18 cm x 50.16 cm - with stand
- 5.9 kg
- DisplayPort 1.2 (HDCP 2.2) , HDMI (HDCP 2.2) , Headphones (mini-jack)
Mechanical
- Tilt
- Tilt Angle
- -2/+25
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x HDMI cable
- Security Slot Type
- Kensington security slot
- Input Voltage
- AC 100-240 V
- Power Consumption SDR (On mode)
- 31 kWh/1000h
- Power Consumption HDR (On mode)
- 57 kWh/1000h
- Power Consumption (Typical)
- 31 Watt
- Power Consumption (Max)
- 100 Watt
- Power Consumption Stand by
- 0.5 Watt
- 0.3 Watt
- Dimensions & Weight Details
- With stand - width: 71.39 cm - depth: 18 cm - height: 50.16 cm - weight: 5.9 kg , Without stand - width: 71.39 cm - depth: 4.18 cm - height: 42.47 cm - weight: 4.4 kg
- Shipping Width
- 79.8 cm
- Shipping Depth
- 54.6 cm
- Shipping Height
- 16 cm
- Shipping Weight
- 8 kg
Sustainability Information
- TCO Certified
- 10 °C
- 40 °C
- 10 - 80% (non-condensing)
