The Samsung ViewFinity S6 is a testament to Samsung's commitment to high-quality, professional-grade monitors. This 34-inch curved monitor is designed to enhance productivity and provide an immersive viewing experience. With its UWQHD resolution of 3440 x 1440, it offers crisp, clear visuals across a wide 21:9 aspect ratio, making it ideal for multitasking and detailed work.
Professionals will appreciate the accurate color representation, thanks to the monitor's 115% sRGB color gamut and support for 1.07 billion colors. Whether it's for design, video editing, or any color-critical work, the Samsung ViewFinity S6 delivers precise and vibrant colors. Additionally, the monitor is equipped with AMD FreeSync technology, ensuring smooth and uninterrupted visuals, which is crucial for both work and play.
The Samsung ViewFinity S6 goes beyond just display capabilities. It features a built-in 5.0 megapixel IR camera, Ethernet network adapter, and a KVM switch, making it a versatile tool for any workspace. With USB-C connectivity offering up to 90 W of power delivery, you can charge your devices directly from the monitor, keeping your workspace clutter-free. The monitor's ergonomic design, with height, swivel, and tilt adjustments, ensures comfort during long hours of work, making it a smart choice for professionals looking to enhance their desktop setup.
- Samsung ViewFinity S6 S34C652VAU - S65VC Series - LED monitor - curved - 34" - HDR
- LED-backlit LCD monitor - 34"
- Energy Class
- Class G
- Energy Consumption per Year
- 47 kWh
- Curved Screen
- Adaptive-Sync Technology
- AMD FreeSync
- KVM Switch, USB 3.0/USB-C hub, Ethernet network adapter, 5.0 megapixel IR camera, USB PD 90 Watt
- Panel Type
- VA
- Aspect Ratio
- 21:9
- Native Resolution
- UWQHD 3440 x 1440 at 100 Hz
- Brightness
- 350 cd/m²
- Contrast Ratio
- 3000:1
- HDR Capable
- HDR10
- Response Time
- 5 ms
- Colour Support
- 1.07 billion colours
- Colour Gamut
- 115% sRGB
- Input Connectors
- HDMI, DisplayPort, USB-C
- Built-in Ethernet
- Height, swivel, tilt
- Voltage
- AC 100-240 V
- Black
- 80.66 cm x 24.1 cm x 56.15 cm
- 8.1 kg
- HDCP 2.2, TUV Rheinland Intelligent Eye Care Certification
- Display Type
- Energy Class
- Class G
- Energy Class (HDR)
- Class G
- 47 kWh
- Diagonal Size
- 34"
- Curved Screen
- Yes (1000R)
- AMD FreeSync
- Built-in Devices
- USB Power Delivery
- 90 Watt
- Panel Type
- VA
- Aspect Ratio
- 21:9
- Native Resolution
- Brightness
- 350 cd/m²
- Contrast Ratio
- 3000:1
- HDR Format
- HDR10
- Colour Support
- Colour Gamut
- 115% sRGB
- Response Time
- 5 ms
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Picture by picture, game mode, CustomColor Mode, FPS Mode, Mega Infinity Dynamic Contrast Ratio, Flicker Free technology, RTS Mode, Image Size, Eye Saver Mode, Off Timer Plus, Sports Mode, RPG Mode, Picture-in-Picture, Auto Source Switch+, Adaptive Picture, Entertain Mode, Graphic Mode, Eco Mode, Original Mode
- Black
- 80.66 cm x 24.1 cm x 56.15 cm - with stand
- 8.1 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 5 Watt
- DisplayPort 1.2 , HDMI , Headphones (mini-jack) , 2 x USB 3.0 downstream , USB 3.0 upstream , USB-C (power up to 90W) , LAN (RJ-45)
Mechanical
- Tilt Angle
- -2/+20
- Swivel Angle
- 60
- Height Adjustment
- 120 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), 3% recycled plastic
- Cables Included
- 1 x HDMI cable , 1 x USB-C cable , 1 x SuperSpeed USB cable , 1 x DisplayPort cable
- Security Slot Type
- Kensington security slot
- Input Voltage
- AC 100-240 V
- Power Consumption SDR (On mode)
- 32 kWh/1000h
- Power Consumption HDR (On mode)
- 51 kWh/1000h
- Power Consumption (Typical)
- 32 Watt
- Power Consumption (Max)
- 200 Watt
- Power Consumption Stand by
- 0.5 Watt
- 0.3 Watt
- Included Software
- Windows Hello
- Dimensions & Weight Details
- With stand - width: 80.66 cm - depth: 24.1 cm - height: 56.15 cm - weight: 8.1 kg , Without stand - width: 80.66 cm - depth: 12.5 cm - height: 36.94 cm - weight: 5.3 kg
- Shipping Width
- 80.7 cm
- Shipping Depth
- 12.5 cm
- Shipping Height
- 36.7 cm
- Shipping Weight
- 10.1 kg
- 10 °C
- 40 °C
- 10 - 80% (non-condensing)
