Choose a more convenient way to access your data on the move. This Samsung optical disc drive (ODD) is ultra slim, so it's easy to take with you wherever you go. It's compatible with all Samsung notebooks, too, and the data connection and power are delivered via only one simple USB cable as well. This means you can use it on the move without searching for power outlets.
Ultra portable and intelligent design
If you like devices that are stylish and powerful, the Samsung ODD is the perfect choice. It features a sleek, ultra slim design, so it's extremely easy to carry. -
Use it, share it, keep it
The stylish ODD is compatible with all Samsung notebooks so it will continue delivering a powerful performance when you upgrade to your next Samsung notebook or netbook. It also provides the added convenience that you can share it with your friends or work colleagues, knowing it will work without any hassles. -
Enjoy ODD performance on-the-go
Forget the hassles of trying to find a power source on the go. Enjoy USB-powered convenience using the hidden cable to connect the ODD to your PC. So whether you are on a train, sitting in the park or just without a power source, the USB 2.0 connection means your ODD's always ready to perform.
- Samsung AA-ES3P95M - DVD±RW (+R DL) / DVD-RAM drive - USB 2.0 - external
- DVD±RW (+R DL) / DVD-RAM drive - external
- Mineral ash black
- Interface
- USB 2.0
- 9.5 mm
- 300 g
- Optical Storage
- DVD±RW (+R double layer) / DVD-RAM
- Read Speed
- 24x (CD) / 8x (DVD)
- Write Speed
- 24x (CD) / 8x (DVD±R) / 6x (DVD+R DL)
- CD / DVD Rewrite Speed
- 24x (CD) / 6x (DVD-RW) / 8x (DVD+RW) / 5x (DVD-RAM)
- Designed For
- Samsung 550; ATIV Smart PC, Smart PC 500, Smart PC Pro, Smart PC Pro 700; ATIV Book 2; 3; 4; 5; 6; 7; 9; 9 Lite; 9 Plus; ATIV Tab 5; N110; N14X; NB30 Plus; NC110; NC210; NC210 Plus; QX310; QX510; RF510; RF710; Series 2; 3; 4; 5; 5 Chronos; 5 Ultra; 6; 7; 7 Chronos; 7 Gamer; 7 Ultra; 9; SF510
- Mineral ash black
- Interface
- USB 2.0
- 9.5 mm
- 300 g
Optical Storage
- Read Speed
- Write Speed
- Access Time
- 160 ms (DVD), 160 ms (CD)
- 1 x USB
- Designed For
- Samsung 550P7C , Samsung ATIV Smart PC, Smart PC 500T, Smart PC Pro, Smart PC Pro 700T , Samsung ATIV Book 2 270E4E, 270E5E, 275E5E , Samsung ATIV Book 3 300E4E , Samsung ATIV Book 4 470R5E , Samsung ATIV Book 5 530U3C, 530U4E, 540U4E , Samsung ATIV Book 6 680Z5E , Samsung ATIV Book 7 730U3E, 740U3E , Samsung ATIV Book 9 900X3E, 900X3F, 900X3G, 900X4C, 900X4D, 930X5J, 930X5JI , Samsung ATIV Book 9 Lite 905S3GI, 915S3GI , Samsung ATIV Book 9 Plus 940X3GI , Samsung ATIV Tab 5 , Samsung N110-anyNet , Samsung Series 2 200B5A A02, 200B5A A03, 200B5AI, 200B5B A01, 200B5BI , Samsung Series 3 , Samsung Series 4 400B2B A04, 400B4B, 400B4B A01, 400B4B H01, 400B4B S01, 400B4B-H03, 400B4BI, 400B4C, 400B4C A01, 400B5B, 400B5B A01, 400B5B A02, 400B5B A03, 400B5B H01, 400B5B S02, 400B5B S03, 400B5BI, 400B5C, 400B5C A03, 400B5C A04, 400B5C-A01, 400B5C-A02, 410B2B A02 , Samsung Series 5 520U4C, 535U3C, 535U4C, 550P5C, 550P7C, 570Z5E , Samsung Series 5 Chronos 570Z5E , Samsung Series 5 Ultra 530U3B, 530U3BI, 530U3C, 530U4B, 530U4BH, 530U4BI, 530U4C, 530U4E, 535U3C, 535U4C, 540U3C , Samsung Series 6 600B4B, 600B4B-A01, 600B4BH, 600B4B-H01, 600B4BI, 600B4C, 600B5B, 600B5B-HC1, 600B5B-HC3, 600B5B-S01, 600B5B-S02, 600B5C, 600B5C-S02, 600B5C-S03 , Samsung Series 7 700G7A, 700G7A-S01, 700G7A-S02, 700G7C, 700Z3A, 700Z3A-B01, 700Z3AH, 700Z3A-S01, 700Z3A-S02, 700Z3C, 700Z3C-S01, 700Z3C-S02, 700Z5A, 700Z5AH, 700Z5A-S01, 700Z5A-S02, 700Z5A-S04, 700Z5BH, 700Z5C, 700Z5CH, 700Z7C, 700Z7CH, 740U3E, 770Z7E, Slate PC , Samsung Series 7 Chronos 700Z3AH, 700Z3A-S01, 700Z3A-S02, 700Z3A-S03, 700Z3C, 700Z3CH, 700Z3C-S05, 700Z3C-S06, 700Z5A, 700Z5AH, 700Z5AI, 700Z5A-S01, 700Z5A-S02, 700Z5A-S03, 700Z5A-S04, 700Z5A-S05, 700Z5A-S06, 700Z5C, 700Z5CH, 700Z5CI, 700Z7C, 700Z7CH, 700Z7C-S02, 700Z7C-S03, 700Z7C-S04, 770Z5E, 770Z7E , Samsung Series 7 Gamer 700G, 700G7A, 700G7A-S01, 700G7C, 700G7C-S01, 700G7C-S04, 700G7C-S07 , Samsung Series 7 Ultra 730U3E, 740U3E
