Samsung UE65KU6400U 65" 4K UltraHD HDR LED Smart TV
Quicklinx: C8YQWS00 Mfr#: UE65KU6400UXXU
Select:
  • 65"
See stunningly natural and lifelike pictures through Samsung’s UHD Crystal Color technology meeting various quality standards. This screen technology delivers enhanced pixels and chip set for a superior picture quality experience with stunning contrast and over 17 million true to life colors with intense shades in a color space wider than conventional UHD.
  • HDR
    The advanced standard for UHD content is High Dynamic Range. UHD TVs that are HDR compliant can all display the content but not all HDR TVs are equal. HDR combined with Crystal Color provides a superior High Dynamic Range experience delivering stunning brightness, enhanced shadow detail and naturally accurate color.
  • Cloud gaming
    Does your TV open up the world of console-less video gaming? Who needs a games console when you can access a wealth of video games from the cloud straight to your TV? Access a huge array of games without the need to invest in a console. Play alongside your favorite stars and race against advanced racing drivers, directly through your TV.
  • UHD Upscaling
    Samsung's unique 4 step UHD Upscaling process converts live TV, your movies and gaming to high resolution, transforming what you watch to premium picture quality. The technology identifies the specific process required to the input signal, noise reduction and upscaling to convert the source material into the UHD resolution of the TV. The last step dedicates resources of the processor to specific areas of the picture requiring detail enhancement. Samsung UHD Upscaling engine raises all conventional content to more impressive quality and with fast and powerful processors it delivers the very best in UHD picture quality.
  • UHD Dimming
    UHD Dimming technology divides the screen into small zones, analyzing each one to adjust color, brightness and sharpness, so you can experience a better picture. The software driven technology improves picture contrast without compromising the overall brightness of the rest of the scene.
  • Ultra Clean View
    Ultra Clean View analyzes the input signal and removes detected noise from the feed. No matter what quality the signal Ultra Clean View improves what you see.
  • Accelerate your Smart TV with Tizen
    Tizen takes Smart TV performance to another level with faster boot times and quick access to Live TV and all your apps. It even provides support for popular local VOD apps for optimized TV viewing.
  • Dive into your video content
    Auto Motion Plus works together to provide enhanced motion with the key motion technologies, image processing speed, backlight technology and frame refresh rate. The end result is impressive clarity for action scenes and sport.
  • Simple and fast wireless connection
    The built-in Wireless Lan lets you connect your Smart TV to the Internet without the tangle of cables. With the streamlined connections, now you can really enjoy your TV's outstanding design.
  • Plug your entertainment into the TV
    Using ConnectShare, you can watch a variety of content in one simple step. Just plug your USB or HDD into the TV and enjoy your movies, music, and pictures on the big screen.
  • Create your own entertainment space
    Samsung TVs support HDMI inputs, which lets you create a multimedia entertainment center in your own living room. Connect HDMI straight into your TV to view various contents from multiple devices.
Samsung UE65KU6400U 6 Series - 65" LED-backlit LCD TV - 4K
LED-backlit LCD TV - Smart TV
Diagonal Class
65"
Silver
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Frame Rate & Enhancement Technology
1500 Picture Quality Index, 100 Hz Motion Rate
Video Interface
Component, composite, HDMI
HDMI Ports Qty
3 ports
Wi-Fi, LAN, Bluetooth
LCD Backlight Technology
LED backlight UHD dimming
Image Aspect Ratio
16:9
TV Tuner
1x analogue, 1x digital
Digital TV Tuner
DVB-C, DVB-S2, DVB-T2
Multi-channel Preview
Picture-in-picture (PIP)
Speaker System
2 speakers
USB
2 ports
Samsung TM1640A remote control, batteries, Samsung TM1240A remote control
Voltage
AC 230V (50/60 Hz)
Energy Class
Class A+
195 Watt
Power Consumption (On mode)
118 W
Energy Consumption per Year
164 kWh
145.81 cm x 5.49 cm x 84.14 cm
23.5 kg
Energy Class
Class A+
195 Watt
118 W
164 kWh
Diagonal Class
65"
Series
6 Series
HDR Capable
Video Processor
Quad-Core
TV Tuner
TV Tuner Presence
Extended PVR
Sensors
Eco Sensor
Video Interface
HDMI Ports Qty
3 ports
Modes
Game mode, Film Mode
Design
Very Narrow Bezel Design (VNB)
Dimensions
Without stand
145.81 cm
5.49 cm
84.14 cm
23.5 kg
Enclosure Colour
Silver
Display
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
Contrast enhancer, time-shift, HDMI quick switch, USB Cloning, Auto Motion Plus, Digital Clean View, E-Manual, UHD Upscaling, Instant On, Mega Dynamic Contrast Ratio, Embeded POP, Ultra Clean View, Accessibility Enlarge, Accessibility High contrast, Accessibility Voice guide, Active Crystal Color
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Flat Panel Mount Interface
TV Tuner
Conditional Access
Common Interface Plus (CI+) slot
Digital TV Tuner
Digital TV Tuner
HDTV Tuner
MPEG Profiles and Levels
MHEG5
Video Features
Electronic Programme Guide
Digital EPG
Media Player
USB Port
USB Ports Qty
2
Remote Control
Remote control
Remote Control Model
Samsung TM1640A
Additional remote control included
Audio System
Digital Audio Format
DTS digital output, Dolby Digital Plus output
Speaker System
2 speakers
Output Power / Total
20 Watt
Down-firing Speaker, Audio Return Channel (ARC), Bass Reflex Speaker System, Wallmount Sound Mode, TV Soundconnect
Speakers
2 x main channel speaker - 10 Watt
Network & Internet Multimedia
Functionality
Digital audio playback, digital photo playback, digital video playback, WEB browsing, Internet video playback
LAN Protocol
Ethernet
Connect & Share
Wi-Fi Direct, Screen Mirroring, USB Human Interface Device (HID), Samsung Smart View, ConnectShare
Supported Consumer Electronics Control (CEC)
Anynet Plus, Multiroom Link
DLNA
Connector Type
3 x HDMI , 2 x USB 2.0 , Composite video / component video input , LAN , Digital audio output (optical) , Audio line-in
Batteries, Samsung TM1240A remote control
Power supply
Input Voltage
AC 230V (50/60 Hz)
Auto On/Off
Dimensions & Weight Details
Panel without stand - 145.81 cm x 5.49 cm x 84.14 cm x 23.5 kg , Panel with stand - 145.81 cm x 32.77 cm x 90.94 cm x 26.8 kg
Width (Shipping)
172.1 cm
Depth (Shipping)
16.8 cm
Height (Shipping)
94.7 cm
Weight (Shipping)
34.8 kg
C8YQ C2G 5m USB 2.0 A/B Cable - Black In Stock £5.09
