Samsung UE55JU6670 55" UHD 4K Curved LED Smart TV
Quicklinx: BDS5WS00 Mfr#: UE55JU6670UXXU
Samsung's revolutionary curved TV makes you feel as though you are right in the middle of the excitement. The UHD screen is curved at the right angle to provide the best viewing distance for your living room, and gives you uniform and balanced viewing from all areas of the screen.
Images come to life with Samsung's Auto Depth Enhancer. By applying different levels of contrast enhancement to different areas on the screen, your entertainment is more immersive. Cinematic shots, from majestic mountains to sweeping panoramas, will seem even more breathtaking. Lifelike viewing with Auto Depth Enhancer.
With picture quality that offers four times the detail of Full HD, the JU6770 TV produces stunningly bright and clearer images. Thanks to PurColor technology, even the most vibrant colors blaze to life as everything shown on the screen is expressed with brighter, richer and more accurate true-to-life tones. The most superior UHD picture quality experience.
  • Immerse in a curved TV experience
  • Lifelike viewing with Auto Depth Enhancer
  • The most superior UHD picture quality experience
  • Experience more accurate and natural colors
    Appreciate the purest expression of color. With the ability to produce more accurate and natural colors than ever before, your TV screen will open a new window to reality.
  • Enhance clarity with brilliant UHD Upscaling
    Samsung's unique UHD experience gets you closer to the action. Enjoy stunningly sharp images and amazing clarity thanks to Samsung's innovative UHD Upscaling technology. It converts lower resolution content - such as live TV - to a level of detail that's four times better than Full HD.
  • Your TV and mobile devices in perfect sync
    Samsung Easy Sharing makes it easy to share content between your TV and mobile. Whether it's a fun video or that must-see TV show Samsung Smart TV picks up the signal when your device is close and seamlessly plays the content perfect for the big screen. It works the other way around, too, so you can move about your house while viewing your favorite content on your device.
  • Powerful quad core performance
    Thanks to a powerful quad core processor, your Samsung Smart TV offers enhanced performance. Enjoy faster multitasking and switch between content and web browsing. Also, you'll notice smoother experience when interacting with your TV.
  • The best Ultra HD movies and TV shows on demand
    Explore a wide range of stunning UHD content from Amazon Prime Instant Video and Netflix. The easy-to-use Apps lets you access the latest Ultra HD movies and TV shows, including Golden Globe award winner Transparent, Mozart In The Jungle & Bosch from Amazon Instant Video, House of Cards and Marvel's Daredevil from Netflix. Just sign up for a free 30-day trial of Amazon Prime Instant Video or Netflix using your Samsung Smart TV and enjoy your favorite entertainment as you've never seen it before.
Samsung UE55JU6670U 6 Series - 55" LED-backlit LCD TV - 4K
Curved LED-backlit LCD TV - Smart TV
Diagonal Class
55"
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Frame Rate & Enhancement Technology
1200 Picture Quality Index
Video Interface
Component, composite, HDMI
HDMI Ports Qty
4 ports
Wi-Fi, LAN, Bluetooth
PC Interface
Mobile High-Definition Link (MHL)
HDCP Compatible
LCD Backlight Technology
LED backlight UHD dimming
Digital TV Tuner
DVB-C, DVB-S2, DVB-T2
Multi-channel Preview
Picture-in-picture (PIP)
Speaker System
2 speakers
Sound Effects
DTS Studio Sound, DTS Premium Audio 5.1
USB
3 ports
Samsung TM1560A remote control, batteries, Samsung TM1240A remote control
Voltage
AC 230V (50/60 Hz)
Energy Class
Class A+
132 Watt
Power Consumption (On mode)
83 W
Power Consumption Stand by
0.3 Watt
Energy Consumption per Year
115 kWh
124.17 cm x 11.19 cm x 71.86 cm
16.2 kg
Curved Screen
Energy Class
Class A+
132 Watt
83 W
115 kWh
Diagonal Class
55"
Series
6 Series
Video Processor
Quad-Core
TV Tuner Presence
Extended PVR
Sensors
Eco Sensor
Video Interface
HDMI Ports Qty
4 ports
PC Interface
HDCP Compatible
Modes
Game mode, Film Mode, Natural Mode, Sports Mode Advanced
Dimensions
Without stand
124.17 cm
11.19 cm
71.86 cm
16.2 kg
Enclosure Colour
Display
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Time-shift, ultra clear panel, Notifications, Auto Motion Plus, Digital Clean View, E-Manual, Auto Depth Enhancer, PurColor, UHD Upscaling, Instant On, Mega Dynamic Contrast Ratio, Embeded POP
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Flat Panel Mount Interface
TV Tuner
Conditional Access
Common Interface Plus (CI+) slot
Digital TV Tuner
Digital TV Tuner
HDTV Tuner
Digital TV Service
HbbTV
Video Features
Teletext
Electronic Programme Guide
Digital EPG
Media Player
USB Port
USB Ports Qty
3
Remote Control
Remote control
Remote Control Model
Samsung TM1560A
Audio System
Digital Audio Format
DTS digital output, Dolby Digital Plus output
Surround Mode
Sound Effects
Speaker System
2 speakers
Output Power / Total
20 Watt
Bass-reflex, Down-firing Speaker, Audio Return Channel (ARC), Voice Interaction
Speakers
2 x main channel speaker - 10 Watt
Network & Internet Multimedia
Functionality
Digital audio playback, digital photo playback, digital video playback, WEB browsing, Internet video playback
LAN Protocol
Ethernet
Connect & Share
Wi-Fi Direct, USB Human Interface Device (HID), Samsung Smart View, ConnectShare
Application Store
Samsung Apps
DLNA
Connector Type
4 x MHL/HDMI input , 3 x USB 2.0 , Headphones , Composite video / component video input , Audio line-in , Digital audio output (optical) , LAN
Batteries, Samsung TM1240A remote control
Power supply
Input Voltage
AC 230V (50/60 Hz)
0.3 Watt
Auto On/Off
WOL (Wake on LAN)
Dimensions & Weight Details
Panel without stand - 124.17 cm x 11.19 cm x 71.86 cm x 16.2 kg , Panel with stand - 124.17 cm x 31.05 cm x 77.93 cm x 17.2 kg
Width (Shipping)
142.7 cm
Depth (Shipping)
19.5 cm
Height (Shipping)
83.5 cm
Weight (Shipping)
23.4 kg
