Samsung's revolutionary curved TV makes you feel as though you are right in the middle of the excitement. The UHD screen is curved at the right angle to provide the best viewing distance for your living room, and gives you uniform and balanced viewing from all areas of the screen.
Images come to life with Samsung's Auto Depth Enhancer. By applying different levels of contrast enhancement to different areas on the screen, your entertainment is more immersive. Cinematic shots, from majestic mountains to sweeping panoramas, will seem even more breathtaking. Lifelike viewing with Auto Depth Enhancer.
With picture quality that offers four times the detail of Full HD, the JU6770 TV produces stunningly bright and clearer images. Thanks to PurColor technology, even the most vibrant colors blaze to life as everything shown on the screen is expressed with brighter, richer and more accurate true-to-life tones. The most superior UHD picture quality experience.
Immerse in a curved TV experience
Samsung's revolutionary curved TV makes you feel as though you are right in the middle of the excitement. The UHD screen is curved at the right angle to provide the best viewing distance for your living room, and gives you uniform and balanced viewing from all areas of the screen. -
Images come to life with Samsung's Auto Depth Enhancer. By applying different levels of contrast enhancement to different areas on the screen, your entertainment is more immersive. Cinematic shots, from majestic mountains to sweeping panoramas, will seem even more breathtaking. Lifelike viewing with Auto Depth Enhancer. -
With picture quality that offers four times the detail of Full HD, the JU6770 TV produces stunningly bright and clearer images. Thanks to PurColor technology, even the most vibrant colors blaze to life as everything shown on the screen is expressed with brighter, richer and more accurate true-to-life tones. The most superior UHD picture quality experience. -
Experience more accurate and natural colors
Appreciate the purest expression of color. With the ability to produce more accurate and natural colors than ever before, your TV screen will open a new window to reality. -
Enhance clarity with brilliant UHD Upscaling
Samsung's unique UHD experience gets you closer to the action. Enjoy stunningly sharp images and amazing clarity thanks to Samsung's innovative UHD Upscaling technology. It converts lower resolution content - such as live TV - to a level of detail that's four times better than Full HD. -
Your TV and mobile devices in perfect sync
Samsung Easy Sharing makes it easy to share content between your TV and mobile. Whether it's a fun video or that must-see TV show Samsung Smart TV picks up the signal when your device is close and seamlessly plays the content perfect for the big screen. It works the other way around, too, so you can move about your house while viewing your favorite content on your device. -
Powerful quad core performance
Thanks to a powerful quad core processor, your Samsung Smart TV offers enhanced performance. Enjoy faster multitasking and switch between content and web browsing. Also, you'll notice smoother experience when interacting with your TV. -
The best Ultra HD movies and TV shows on demand
Explore a wide range of stunning UHD content from Amazon Prime Instant Video and Netflix. The easy-to-use Apps lets you access the latest Ultra HD movies and TV shows, including Golden Globe award winner Transparent, Mozart In The Jungle & Bosch from Amazon Instant Video, House of Cards and Marvel's Daredevil from Netflix. Just sign up for a free 30-day trial of Amazon Prime Instant Video or Netflix using your Samsung Smart TV and enjoy your favorite entertainment as you've never seen it before.
- Samsung UE55JU6670U 6 Series - 55" LED-backlit LCD TV - 4K
- Product Type
- Curved LED-backlit LCD TV - Smart TV
- Diagonal Class
- 55"
- Black
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- Frame Rate & Enhancement Technology
- 1200 Picture Quality Index
- Video Interface
- Component, composite, HDMI
- HDMI Ports Qty
- 4 ports
- Connectivity
- Wi-Fi, LAN, Bluetooth
- PC Interface
- Mobile High-Definition Link (MHL)
- HDCP Compatible
- LCD Backlight Technology
- LED backlight UHD dimming
- Digital TV Tuner
- DVB-C, DVB-S2, DVB-T2
- Multi-channel Preview
- Picture-in-picture (PIP)
- Speaker System
- 2 speakers
- Sound Effects
- DTS Studio Sound, DTS Premium Audio 5.1
- USB
- 3 ports
- Included Accessories
- Samsung TM1560A remote control, batteries, Samsung TM1240A remote control
- Voltage
- AC 230V (50/60 Hz)
- Energy Class
- Class A+
- 132 Watt
- Power Consumption (On mode)
- 83 W
- Power Consumption Stand by
- 0.3 Watt
- Energy Consumption per Year
- 115 kWh
- Dimensions (WxDxH) - without stand
- 124.17 cm x 11.19 cm x 71.86 cm
- 16.2 kg
- Curved Screen
- Product Type
- Energy Class
- Class A+
- 132 Watt
- 83 W
- 115 kWh
- Diagonal Class
- 55"
- Series
- 6 Series
- Video Processor
- Quad-Core
- TV Tuner Presence
- Extended PVR
- Sensors
- Eco Sensor
- Video Interface
- HDMI Ports Qty
- 4 ports
- PC Interface
- HDCP Compatible
- Modes
- Game mode, Film Mode, Natural Mode, Sports Mode Advanced
- Dimensions
- Without stand
- 124.17 cm
- 11.19 cm
- 71.86 cm
- 16.2 kg
- Enclosure Colour
- Black
Display
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- Time-shift, ultra clear panel, Notifications, Auto Motion Plus, Digital Clean View, E-Manual, Auto Depth Enhancer, PurColor, UHD Upscaling, Instant On, Mega Dynamic Contrast Ratio, Embeded POP
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Flat Panel Mount Interface
TV Tuner
- Conditional Access
- Common Interface Plus (CI+) slot
Digital TV Tuner
- Digital TV Tuner
- HDTV Tuner
- Digital TV Service
- HbbTV
Video Features
- Teletext
- Electronic Programme Guide
- Digital EPG
Media Player
- USB Port
- USB Ports Qty
- 3
Remote Control
- Remote control
- Remote Control Model
- Samsung TM1560A
Audio System
- Digital Audio Format
- DTS digital output, Dolby Digital Plus output
- Surround Mode
- Sound Effects
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Bass-reflex, Down-firing Speaker, Audio Return Channel (ARC), Voice Interaction
- Speakers
- 2 x main channel speaker - 10 Watt
Network & Internet Multimedia
- Functionality
- Digital audio playback, digital photo playback, digital video playback, WEB browsing, Internet video playback
- Connectivity
- LAN Protocol
- Ethernet
- Connect & Share
- Wi-Fi Direct, USB Human Interface Device (HID), Samsung Smart View, ConnectShare
- Application Store
- Samsung Apps
- DLNA
- Connector Type
- 4 x MHL/HDMI input , 3 x USB 2.0 , Headphones , Composite video / component video input , Audio line-in , Digital audio output (optical) , LAN
- Batteries, Samsung TM1240A remote control
- Power Device
- Power supply
- Input Voltage
- 0.3 Watt
- Auto On/Off
- WOL (Wake on LAN)
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 124.17 cm x 11.19 cm x 71.86 cm x 16.2 kg , Panel with stand - 124.17 cm x 31.05 cm x 77.93 cm x 17.2 kg
- Width (Shipping)
- 142.7 cm
- Depth (Shipping)
- 19.5 cm
- Height (Shipping)
- 83.5 cm
- Weight (Shipping)
- 23.4 kg
