The Samsung UE55D features a stylishly thin chassis with a slim bezel to bezel (BtB) spec, combined with an upgraded Samsung SMART Signage Platform. Create beautiful video walls in full HD with no PC, DVD or SBB required. Built-in Wi-Fi allows for easy mobile control and increased Daisy Chain capability, while compatibility with the predecessor UE-C models provides versatile options.
Edge-Lit LED display
The edge-lit 55" display of the UE55D features full HD resolution to deliver sharp, detail-rich images and crisp type. The narrow bezels, at 11mm BtB, elegantly complement the visuals thanks to minimal distraction. -
Enhanced SSP with quad core processor
Experience 2x SoC performance thanks to SSP with a quad core processor. SSP is an integrated, open platform providing a powerful streamlined solution to reduce TCO in digital signage deployments through savings in hardware installation and operating costs. -
Ultra-slim 1.2" chassis
A stylishly thin chassis helps to create sophisticated videowalls that can inspire your audience. The ultra-slim design also helps to simplify installation while meeting ADA compliance requirements. -
PC-Less Videowalls
Create beautiful video walls with no PC, DVD or SBB. Use only USB with Display Port 1.2 Loop In/Out. Users can benefit from the simplified process and less equipment requirements for videowall installation and content playing. -
Built-In Wi-Fi
Experience easy mobile control and increased Daisy Chain capability thanks to built-in Wi-Fi. Use AllShare Cast (sold separately) over a Wi-Fi connection for simple content mirroring from a tablet or mobile phone to your display.
- Samsung UE55D UE-D Series - 55" LED-backlit LCD display - Full HD - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 55"
- Commercial Use
- Yes - digital signage
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Max Number of Screens
- 225
- Video Interface
- Component, composite, HDMI
- HDMI Ports Qty
- 1 ports
- Connectivity
- Wi-Fi
- PC Interface
- DVI, VGA (HD-15), DisplayPort
- HDCP Compatible
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Commercial Features
- Button lock, SMART Signage Platform, Image Rotation, Magic Clone, Auto Source Switching & Recovery, Lamp Error Detection
- Speaker System
- 2 speakers
- Supported Memory Cards
- SD Memory Card
- USB
- Included Accessories
- Remote control
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class B
- 154 Watt
- Power Consumption (On mode)
- 120 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 175 kWh
- Dimensions (WxDxH) - without stand
- 122.24 cm x 3.13 cm x 69.32 cm
- 13.3 kg
- Environmental Standards
- ENERGY STAR Qualified
- Product Type
- Energy Class
- Class B
- 154 Watt
- 120 W
- 175 kWh
- Diagonal Class
- 55"
- Commercial Use
- Series
- UE-D Series
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Temperature sensor
- Video Interface
- HDMI Ports Qty
- 1 ports
- PC Interface
- HDCP Compatible
- Modes
- Portrait mode, landscape mode
- Design
- Narrow Bezel Design
- Dimensions
- Without stand
- 122.24 cm
- 3.13 cm
- 69.32 cm
- 13.3 kg
Display
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- LED backlight
- Coating
- Super Clear
- Colour Depth
- Up to 1.07 billion colours
- Image Contrast Ratio
- 4000:1
- Brightness
- 450 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Pixel Pitch
- 0.21 x 0.63mm
- Response Time
- 8 ms
- Pivot, Multiple Display Control (MDC), digital daisy chain, Smart Scheduling, e-LED BLU, MagicInfo Player-S2
Video Wall
- 225
Stands & Mounts
- Stand
- Optional
- Flat Panel Mount Interface
- 400 x 400 mm
Media Player
- SD Memory Card
- USB Port
- USB Ports Qty
- 1
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Speakers
- 2 x speaker - 10 Watt
Network & Internet Multimedia
- Functionality
- Digital audio playback, digital photo playback, digital video playback
- Connectivity
- Wi-Fi
- Connector Type
- Serial input , Serial output , Remote control/ambient sensor input , Audio line-in , Audio line-out , USB 2.0 , HDMI input , DisplayPort input , DisplayPort output , DVI-D input , VGA input , Composite video / component video / audio input , LAN , Remote control output
- Cables Included
- DisplayPort cable
- Plug and Play, TUV, C-Tick, GOST, cUL, DDC-2B, EN 60950, EN55022, NOM, PCBC, SASO, SIQ, IEC 60950, EN55024, UL 60950, CISPR 22, CB, CCC, EMC, PSB, EK, AS/NZS 3548, IRAM, BSMI CNS 13438, FCC Part 15 B Class A, VCCI V-3, GB 9254-2008, GB 17625.1-2003 EMC, KCC KN22, KCC KN24, K60950, GB 4943.1, IS13252, NOM-001-SCFI-1993, BIS
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 6.0
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- Width (Shipping)
- 134 cm
- Depth (Shipping)
- 14.5 cm
- Height (Shipping)
- 80 cm
- Weight (Shipping)
- 17.8 kg
- 0 °C
- 40 °C
- 10 - 80%
