- Bring your audience a superior picture
- Elevate messaging quality through incredible clarity
- Use a single platform for content creation and management
- Maintain consistent performance in varying environments
Achieve ultimate picture quality through advanced factory calibration
Any irregularity in a video wall's brightness and color accuracy across displays can negatively impact the viewing experience. To eliminate these types of color expression gaps and maintain a fully-aligned, consistent and captivating presentation, Samsung's UDE-B series video walls feature advanced factory tuning, innovative hardware and exceptional user calibration tools. Samsung's multi-step factory calibration process tunes video wall displays to the highest-performing uniform brightness and color across each display out-of-the-box. After calibration, these displays offer an industry-leading local uniformity of more than 90 percent across 25 (5x5) areas of each display screen, resulting in uniform color expression across the entire display. The calibration process also enables the displays to offer a superior white balance difference of less than 300 degrees K. In addition to rigorous factory calibration, users can manage brightness and color uniformity conveniently with Samsung Color Expert, a powerful free software program. Through these advanced color management solutions, the UDE Series video walls enable large-scale presentations to feature superior uniformity, consistency and performance for the ultimate in color expression. -
Captivate audiences through a narrow bezel and optimized panel design
The enhanced panel quality of Samsung's UDE-B video wall elevates visual messaging and content through a seamless image and superior clarity. Featuring an ultra-narrow 3.5 mm bezel-to-bezel design format (2.3 mm bezel on the left and top sides and 1.2 mm bezel on the right and bottom sides), which is the slimmest bezel in the video wall industry, the display creates a virtually uninterrupted viewing experience to keep audiences focused on content rather than the display itself. When exposed to a range of environmental conditions, video wall panels can run the risk of losing image quality due to distortion and irregular color presentation. To provide consistent display clarity uninterrupted message delivery in any operational environment, Samsung's UDE-B video wall panels undergo rigorous performance testing. Each display features a reinforced panel that deters heat, weather and other stress-inducing conditions. As a result, Samsung's superior panel prevents screen darkening, light leakage or any related deterioration in picture quality. Plus, an anti-glare panel to ensure messages reach relevant audiences with minimal distraction by light reflection - All these enhanced panel quality allows the long term delivery of brilliant contents and the ultimate viewing experience -
Achieve UHD picture quality without additional devices through industry-leading technology
With an increase in screen size, content resolution becomes even more important to deliver impactful content. As the industry's first video walls to feature integrated DisplayPort (DP) 1.2 and HDMI ports, Samsung's UDE-B Series video walls, UDE-B, can display Ultra-High Definition (UHD) contents across video wall configurations as large as 5 x 5 without the purchase of additional expensive devices. In comparison to conventional video walls that typically require added equipment and only accommodate up to a 2 x 2 arrangement, the UDE-B Series' UHD presentation represents a sharp improvement. By supporting High-Bandwidth Content Protection (HDCP) daisy chains, the UDE-B Series video walls also can display UHD content, such as live TV or Blu-Ray discs, without having to purchase additional equipment, minimizing the cost of deploying multiple displays as part of large-scale promotional signage or informational presentations. -
High-performing display readability and durability for your business environment
Samsung's UDE-B Series video walls deliver a continuously immersive and engaging viewing experience through high-performing readability and durability. Designed for 24/7 continuous operation in challenging environments, the UDE-B Series video walls operate at the speed of your business without losing performance or display quality. The displays offer 500 nit brightness to broadcast vivid, highly legible images and visual messaging in various lighting conditions. The combination of these embedded design benefits makes the UDE-B Series video walls ideal for content and information delivery in usage environments that require enhanced readability, such as transportation terminals, shopping malls, office lobbies and control rooms.
- Samsung UD46E-B 46" LED-backlit LCD display - Full HD - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 46"
- Commercial Use
- Yes - digital signage
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Max Number of Screens
- 225
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- PC Interface
- DVI, VGA (HD-15), DisplayPort
- HDCP Compatible
- LCD Backlight Technology
- LED backlight
- TV Tuner
- No tuner
- Included Accessories
- Remote control, batteries
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class G
- 143 Watt
- Power Consumption (On mode)
- 144 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 175 kWh
- Dimensions (WxDxH) - without stand
- 102.21 cm x 9.74 cm x 57.66 cm
- 18 kg
- Environmental Standards
- ENERGY STAR Qualified
- Product Type
- Energy Class
- Class G
- 143 Watt
- 144 W
- Power Consumption SDR (On mode)
- 144 kWh/1000h
- 175 kWh
- Diagonal Class
- 46"
- Commercial Use
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Temperature sensor
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- PC Interface
- HDCP Compatible
- Dimensions
- Without stand
- 102.21 cm
- 9.74 cm
- 57.66 cm
- 18 kg
Display
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- LED backlight
- Colour Depth
- 16.7 million colours
- Image Contrast Ratio
- 3500:1
- Dynamic Contrast Ratio
- 10000:1
- Brightness
- 500 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Pixel Pitch
- 0.53025 x 0.53025mm
- Response Time
- 8 ms
- 10 x10 Daisy-Chain support
Video Wall
- 225
Stands & Mounts
- Flat Panel Mount Interface
- 600 x 400 mm
Remote Control
- Remote control
- Connector Type
- VGA input , DVI-D input , 2 x HDMI input , DisplayPort input , DisplayPort output , Audio line-in , Serial , Audio line-out , Remote control
- Batteries
- Cables Included
- DisplayPort cable
- CSA, UL, TUV, C-Tick, GOST, EN55022, NEMKO, NOM, PCBC, SASO, EN55024, CCC, PSB, AS/NZS 3548, UL 60950-1, IEC 60950-1, EN 60950-1, KCC, BSMI CNS 13438, FCC Part 15 B Class A, VCCI V-3, GB 9254-2008, GB 17625.1-2003 EMC, KN22, KN24, K60950-1, CAN/CSA-C22.2 No. 60950-1
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 6.0
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- Width (Shipping)
- 116 cm
- Depth (Shipping)
- 28 cm
- Height (Shipping)
- 71.5 cm
- Weight (Shipping)
- 22.4 kg
- 0 °C
- 40 °C
- 10 - 80%
