Samsung UD46D-P SMART signage with FHD can take your digital messaging to the next level thanks to unsurpassed Samsung bezel innovation. These never before seen bezel displays can amaze audiences when combined together to form seamless video walls with virtually no visual distraction. The UD46D-P bezels are invisible to the naked eye creating a truly uninterrupted image for optimized visual messaging. Use this cutting-edge display technology to entice customers into your retail shop, replace traditional whiteboards in your corporate meeting room or provide important real-time information in public places. Additionally, provide highly bright, vibrant picture quality without glare or blurriness to completely captivate audiences with a powerful viewing experience.
Provide seamless viewing
Samsung UD46D-P SMART signage with FHD can take your digital messaging to the next level thanks to unsurpassed Samsung bezel innovation. These never before seen bezel displays can amaze audiences when combined together to form seamless video walls with virtually no visual distraction. The UD46D-P bezels are invisible to the naked eye creating a truly uninterrupted image for optimized visual messaging. Use this cutting-edge display technology to entice customers into your retail shop, replace traditional whiteboards in your corporate meeting room or provide important real-time information in public places. Additionally, provide highly bright, vibrant picture quality without glare or blurriness to completely captivate audiences with a powerful viewing experience. -
Simplify content delivery with a hassle-free all-in-one video wall solution
Improve productivity and reduce operating costs by installing and configuring the signage solution with greater ease. The embedded, all-in-one eliminates the need for a separate PC or media player to streamline digital signage operation and improve total cost of ownership. In addition, the SSSP supports a picture-in-picture for operational excellence. To boost efficiency, content deployment and sharing is simplified with a PC-less network connection that lets you plug in a USB and link multiple displays over a daisy chain configuration. -
Easily manage digital signage
Frequently used functions are conveniently available on the Home screen in a matrix design represented by large menu buttons for ease of use. A selection of menu configurations is also displayed on the Home screen, which can be customized to populate repeatedly used menus instead of using the default selection, for quick access. UD46D-P SMART signage also provides powerful content management tools, upgraded for your business use. -
Amaze your viewers with pinpoint color accuracy across multiple displays
Maintaining consistent color across multiple displays becomes easier for businesses with UDD Series displays. The displays undergo a meticulous factory color calibration process, ensuring accurate color without image distortion and without the need for manual calibration. The improved factory color tuning for white balancing and color difference compensation ensure that the displays present images in uniform color with color temperature matching. Users can fine-tune the colors with Samsung Color Expert, which offers more detailed management for any custom needs and provides added convenience by reducing calibration time. Color vibrancy can be calibrated automatically or manually. Plus, color values can be shared between multiple displays, ensuring outstanding intensity across all video wall screens, dazzling the audience. -
Display content optimally with easy image rotation
Whether using a single display or a video wall, you can create content in portrait or landscape mode - and then rotate it. UDD Series displays include a pivot function and image rotation function that display content vertically or horizontally without ratio distortion. You can conveniently and accurately rotate your content with display options: original ratio on a single screen, full ratio on a single screen or full ratio on a video wall.
- Samsung UD46D-P UD-D Series - 46" LED-backlit LCD display - Full HD - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 46"
- Commercial Use
- Yes - digital signage
- Black
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Max Number of Screens
- 100
- Video Interface
- Component, composite, HDMI
- HDMI Ports Qty
- 2 ports
- Connectivity
- Wi-Fi, LAN
- PC Interface
- DVI, VGA (HD-15), DisplayPort
- HDCP Compatible
- LCD Backlight Technology
- Direct-lit LED
- TV Tuner
- No tuner
- Commercial Features
- Button lock, Image Rotation, Magic Clone, Auto Source Switching & Recovery, Lamp Error Detection, SMART Signage Platform 2nd Generation
- Settings Cloning Capability
- Supported Memory Cards
- SD Memory Card
- USB
- Included Accessories
- Remote control
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class C
- Power Consumption (On mode)
- 130 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 190 kWh
- Dimensions (WxDxH) - without stand
- 102.21 cm x 9.7 cm x 57.67 cm
- 18 kg
- Environmental Standards
- ENERGY STAR Qualified
- Product Type
- Energy Class
- Class C
- 130 W
- 190 kWh
- Diagonal Class
- 46"
- Commercial Use
- Series
- UD-D Series
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Temperature sensor
- Video Interface
- HDMI Ports Qty
- 2 ports
- PC Interface
- HDCP Compatible
- Dimensions
- Without stand
- 102.21 cm
- 9.7 cm
- 57.67 cm
- 18 kg
- Enclosure Colour
- Black
Display
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Direct-lit LED
- Coating
- Anti-glare
- Colour Depth
- 16.7 million colours
- Image Contrast Ratio
- 3500:1
- Dynamic Contrast Ratio
- 10000:1
- Brightness
- 700 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Pixel Pitch
- 0.53025 x 0.53025mm
- Response Time
- 8 ms
- Pivot, Multiple Display Control (MDC), digital daisy chain, Anti Retention, MagicInfo, DID technology, Smart Scheduling, Advanced Color Management, MagicInfo Videowall-S, MagicInfo Player-S2
Video Wall
- 100
Stands & Mounts
- Stand
- Optional
- Flat Panel Mount Interface
- 600 x 400 mm
Media Player
- SD Memory Card
- USB Port
- USB Ports Qty
- 1
Remote Control
- Remote control
Network & Internet Multimedia
- Connectivity
- Wi-Fi, LAN
- Connector Type
- 2 x HDMI input , Composite video / component video / audio input , DVI-D input , VGA input , Audio line-out , Serial input , Multiple Display Control , USB 2.0 , DisplayPort input , Serial output , DisplayPort output , Audio line-in
- Cables Included
- DisplayPort cable
- Plug and Play, FCC Class B certified, CSA, UL, TUV, C-Tick, BSMI, GOST, DDC-2B, EN55022, NEMKO, NOM, PCBC, SASO, SIQ, EN55024, CISPR 22, FCC Part 15 B, CCC, PSB, AS/NZS 3548, IRAM, UL 60950-1, EN 60950-1, ISO 9241-307, KCC, CSA C22.2 No. 60950-1, VCCI V-3, KC, GB 9254-2008, NOM-019-SCFI-1993 IRAM, KN22, KN24, K60950-1, CNS 13438, IEC60950-1, GB 17625.1-2011, GB4943.1-2001
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 6.0
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- Width (Shipping)
- 125.5 cm
- Depth (Shipping)
- 35.5 cm
- Height (Shipping)
- 79.8 cm
- Weight (Shipping)
- 22.4 kg
- 0 °C
- 40 °C
- 10 - 80%
