The UE850 UHD monitors offer rich picture contrast and rapid response time, creating a more life-like, non-distracting visual experience that simultaneously enhances performance. The UE850's improved resolution and dynamic connectivity drive efficiency for professional, creative and analytical tasks. Combined with ergonomic and environmentally-friendly advancements, these UE850 monitors deliver a complete, comfortable viewing experience.
Enhanced visual performance
Through the presentation of more than 8 million pixels and four-times the detail clarity of full high-definition (FHD) alternatives, the UE850 provides the most accurate image recreation possible. Samsung's monitors create a true UHD viewing experience through a host of embedded picture- and game-enhancing functions. The UE850 are the only UHD monitors supporting AMD FreeSync technology, which synchronizes the refresh rate of the monitor to the frame rate of a user's AMD graphic card for a smooth, responsive and tearing-free game. Response times as fast as one millisecond in the 28-inch models also allows gamers to see even the fastest on-screen action clearly and smoothly without motion blur or ghosting, while a 60 Hz refresh rate further eliminates picture choppiness and fosters a smoother, non-distracting viewing environment. -
Versatile multi-tasking connectivity
By offering advanced connectivity, the UHD monitors expand user functionality for greater flexibility and convenience. While both UHD monitors have integrated DisplayPort (DP) and HDMI ports, UE850 business monitors feature a Quad interface that seamlessly connects with DP 2.1, miniDP, HDMI 2.0 and HDMI 1.4a sources. HDMI 2.0 and DP 2.1 support 4K resolution at 60Hz, which is double the maximum resolution of HDMI 1.4a (4K at 30Hz). The UE850 also comes with four USB 3.0 ports, with two offering super-charging capability. Since the super-charging USBs enable the simultaneous charging of multiple mobile devices that is three times faster than a normal USB 2.0 port, the need for a docking station is eliminated. As a result, professionals can upload and view almost any content type while concurrently charging multiple devices. To promote productivity, the UE850 allowes users to align on-screen content with their specific viewing needs. A picture-by-picture (PBP) mode ensures content can be displayed from two different input sources while maintaining picture quality. Similarly, up to 25 percent of the screen can be repositioned and resized anywhere within the screen using the Picture-in-picture 2.0 (PiP) mode. -
Display comfort and functionality
Improved ergonomic benefits deliver a more comfortable, enjoyable experience for UE850 users. The UHD monitors come with VESA-supported wall mounts, and the UE850 further extends viewing capabilities through a height-adjustable stand (HAS) and tilt, pivot and swivel capabilities. Professionals can also maintain aspect ratio consistency when pivoting the UE850 business monitor with a built-in auto on-screen display (OSD) rotation function and auto magic rotation software. Designed for extended periods of screen use, the UE850 make the viewing experience less strenuous. Using a unique eye-saver mode, the monitors reduce the harmful effects of blue light on viewers' eyes and associated eye strain. Similarly, the monitors' flicker-free function protects viewers' eyes from the constant strain of flickering screens that can be experienced with standard monitors. -
Eco-friendly performance
The UHD monitors reinforce Samsung's commitment to deliver high-performing technologies in a more sustainable manner. To help businesses conserve energy, resources and costs, the UE850 is constructed using 30 percent recycled plastic and a PVC-free body, while also featuring the energy-conserving technologies. The UE850's off timer plus function reduces power consumption and enables power-off scheduling, while the smart eco-saving function helps reduce screen brightness for increased energy efficiency.
- Samsung U32E850R - UE850 Series - LED monitor - 31.5"
- LED-backlit LCD monitor - 31.5"
- Energy Class
- Class B
- Energy Consumption per Year
- 89 kWh
- Power Consumption (On mode)
- 62 W
- Adaptive-Sync Technology
- AMD FreeSync
- USB 3.0 hub
- Panel Type
- Plane to Line Switching (PLS)
- Aspect Ratio
- 16:9
- Native Resolution
- 4K UHD (2160p) 3840 x 2160 at 60 Hz
- Pixel Pitch
- 0.1815 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 4 ms (black-to-white)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 97% sRGB
- Input Connectors
- 2xHDMI, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V
- Black, titan silver
- 74.03 cm x 27.86 cm x 49.35 cm
- 9.61 kg
- Environmental Standards
- ENERGY STAR Qualified
- TUV GS, C-Tick, GOST, EN55022, NEMKO, NOM, PCBC, SASO, SIQ, EN55024, CCC, PSB, AS/NZS 3548, IRAM, UL 60950-1, IEC 60950-1, EN 60950-1, CSA C22.2 No. 60950-1, FCC Part 15 B Class A, GB 17625.1, VCCI V-3, GB 9254-2008, K60950-1, KCC KN22, KCC KN24, CNS 14336, CNS 13438, GB 4943-2011
- Display Type
- Energy Class
- Class B
- 89 kWh
- Diagonal Size
- 31.5"
- AMD FreeSync
- Built-in Devices
- USB 3.0 hub
- Panel Type
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.1815 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Colour Gamut
- 97% sRGB
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- MagicBright, picture by picture, MagicRotation, game mode, Mega Dynamic Contrast Ratio, Flicker Free technology, BFR/PVC-free, Image Size, PIP 2.0, USB Super-charging, Eye Saver Mode
- 74.03 cm x 27.86 cm x 49.35 cm - with stand
- 9.61 kg
- Headphones , 2 x HDMI , DisplayPort , 4 x USB 3.0
Mechanical
- Tilt Angle
- -5/+22
- Swivel Angle
- 50
- Rotation Angle
- -1.5/+91.5
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x HDMI cable , 1 x Mini DisplayPort-DisplayPort cable , 1 x SuperSpeed USB cable
- Input Voltage
- AC 120/230 V
- 62 W
- Power Consumption Stand by
- 0.4 Watt
- Power Consumption Sleep
- 0.3 Watt
- OS Required
- Apple MacOS, Windows 8.1
- Dimensions & Weight Details
- With stand - width: 74.03 cm - depth: 27.86 cm - height: 49.35 cm - weight: 9.61 kg , Without stand - width: 74.03 cm - depth: 6.77 cm - height: 43.98 cm - weight: 6.8 kg
Sustainability Information
- ENERGY STAR Certified
- 10 °C
- 40 °C
- 10 - 80% (non-condensing)
