Featuring a 32" UHD screen, this monitor provides nearly four times greater resolution than standard 1920 x 1080 FHD. View content with significantly greater precision and detail. So you can enjoy exceptional viewing clarity, be more productive and maximize efficiency.
White balance correction
Enjoy perfectly corrected white balance for accurate color thanks to advanced H/W calibration technology and white balance correction. The UD970 knows the exact white balance needed and expertly corrects the temperature for a more vivid picture quality. -
Meticulous pre-calibration process
Each monitor is individually calibrated at the factory to provide uniform color presentation across the entire screen, even in the corners of the display area, eliminating darker colors appearing around the screen's periphery. -
Color details and clarity in every shade of gray
Carefully calibrated with Gamma Curve and Gray Scale Correction ensures images are lifelike, with the correct amount of light, shade and color to express every detail. This correction of Gray Scale and Gamma Curve is crucial to producing high-detail, high-quality work that you will always be proud of. -
Minimalistic, ergonomic design
The minimalistic design provides a clean aesthetic, making it a pleasure to work. The ergonomic stand with sophisticated hinge technology allows for versatile height adjustment, tilt, swivel and pivot. So you can fit the monitor to your everyday needs. -
Dual color mode
View two different single-color modes in one screen. With Dual Color Mode you can easily view color comparison of two images simultaneously, regardless of the image sources.
- Samsung U32D970Q - UD970 Series - LED monitor - 31.5"
- LED-backlit LCD monitor - 31.5"
- Energy Class
- Class D
- Energy Consumption per Year
- 131 kWh
- Power Consumption (On mode)
- 90 W
- USB 3.0 hub
- Panel Type
- Plane to Line Switching (PLS)
- Native Resolution
- 4K UHD (2160p) 3840 x 2160 (DisplayPort: 60 Hz, HDMI: 30 Hz, DVI: 30 Hz)
- Pixel Pitch
- 0.1816 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 8 ms (grey-to-grey)
- Colour Support
- 1.07 billion colours
- Input Connectors
- HDMI, DVI-D, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Matte black, titan silver
- 72.78 cm x 28 cm x 62 cm
- 13.7 kg
- Environmental Standards
- ENERGY STAR Qualified
- UL, TUV GS, RoHS, EMI, FOGRA
- 3-year warranty
- Display Type
- Energy Class
- Class D
- 131 kWh
- Diagonal Size
- 31.5"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- Native Resolution
- Pixel Pitch
- 0.1816 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Power off timer, MagicBright 3, game mode, Mega Dynamic Contrast Ratio, Eco Light Sensor, Eco Saving, Lifelike Color, Magic Upscale, Mercury free, Image Size, PIP 2.0, PBP, USB Super-charging, OSD Auto Rotate, AutoPivot sensor, programmable key
- 72.78 cm x 28 cm x 62 cm - with stand
- 13.7 kg
- 5 x USB 3.0 , HDMI , 2 x DisplayPort , DVI-D , Audio line-out
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 60
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm, 200 x 200 mm
- Cables Included
- 1 x USB cable , 1 x DVI cable
- Power Supply
- Internal
- 90 W
- Power Consumption Stand by
- 0.5 Watt
- Included Software
- Drivers & Utilities, Samsung MultiScreen
- OS Required
- Apple MacOS, Windows 8.1
- Dimensions & Weight Details
- With stand - width: 72.78 cm - depth: 28 cm - height: 62 cm - weight: 13.7 kg , Without stand - width: 72.78 cm - depth: 6.21 cm - height: 42.73 cm - weight: 10.3 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 36 months
