Blending infinitesimal quantum dots with billions of hues, the UH75 restores images in their true colors, vividly and accurately. Especially with greens and reds refreshingly freed from desaturation, what you see on the screen simply comes alive as if unmediated by a screen. Samsung's Picture-by-Picture capabilities let you connect to two different devices at the same time while still maintaining the original image quality. The Picture-in-Picture feature allows you to do away with the need for a second monitor even when you are multitasking. You can resize the second image and position it anywhere you wish. Slim-bodied with narrow bezels and its sleek back, the UH75 in short is a performance in beauty. Its urbane, modern appeal will seamlessly blend in with any décor of your choice.
- Samsung U28H750UQU - UH75 Series - LED monitor - 4K - 28"
- LED-backlit LCD monitor - 28"
- Energy Class
- Class B
- Energy Consumption per Year
- 50 kWh
- Power Consumption (On mode)
- 34 W
- Adaptive-Sync Technology
- AMD FreeSync
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- 4K 3840 x 2160 at 60 Hz
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 1 ms (grey-to-grey)
- Colour Support
- 1.07 billion colours
- Input Connectors
- 2xHDMI, DisplayPort
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black, silver
- 65.37 cm x 24.28 cm x 47.63 cm
- 5.2 kg
- Environmental Standards
- ENERGY STAR Qualified
- Display Type
- Energy Class
- Class B
- 50 kWh
- Diagonal Size
- 28"
- Viewable Size
- 27.9"
- AMD FreeSync
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Response Time
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- LED backlight
- Picture in picture, MagicBright, picture by picture, game mode, Mega Dynamic Contrast Ratio, Black eQualizer, Flicker Free technology, Eye Saver Mode, Factory Calibration Report, Off Timer Plus, Quantum Dot Technology
- Black, silver
- 65.37 cm x 24.28 cm x 47.63 cm - with stand
- 5.2 kg
- DisplayPort , 2 x HDMI , Headphones
Mechanical
- Tilt
- Tilt Angle
- -1/+20
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x HDMI cable , 1 x DisplayPort cable
- Input Voltage
- 34 W
- Power Consumption (Typical)
- 34 Watt
- Power Consumption Stand by
- 0.3 Watt
- 0.3 Watt
- Included Software
- Easy Setting Box
- Dimensions & Weight Details
- With stand - width: 65.37 cm - depth: 24.28 cm - height: 47.63 cm - weight: 5.2 kg , Without stand - width: 65.37 cm - depth: 9.46 cm - height: 37.6 cm - weight: 4.7 kg
Sustainability Information
- ENERGY STAR Certified
- 10 °C
- 40 °C
- 10 - 80% (non-condensing)
