Samsung U28E590D 28" 3840x2160 1ms HDMI DisplayPort LED Monitor
Quicklinx: B8M0WS00 Mfr#: LU28E590DS/EN
The Samsung UE590 UHD monitor offers PC viewing, gaming and more, all in stunning Ultra HD picture quality. Superb images that boast a staggering 8 million pixels are delivered at a resolution 4x greater than Full HD. See your 4K content the way it was meant to be seen, with realistic detail that makes you feel like you're really there. Experience a new level of clarity in Ultra High Definition.
  • Discover the detail of stunningly realistic UHD picture quality
  • Take your entertainment to new heights of immersion and comfort
    AMD FreeSync: dynamically syncs the screen refresh rate with the frame rate of your content to minimize input latency and dramatically reduce image tearing and stutter during gaming. Upgraded HDMI Support: With an upgraded HDMI that supports UHD resolutions at a 60 Hz refresh rate, 4K content plays smoothly without delay, even when connected to AV devices. Instantly adjust your monitor settings for an optimized gaming experience through the on-screen display. Game Mode improves the darkness of the picture so that you can see all the action vividly. Fast 1ms Response Time: See even the fastest on-screen motion clearly without any motion blur, judder or ghosting.
  • Experience unbeatable picture quality with razor sharp resolution and billions of colors
    1 billion colors: with 64 times more colors than conventional monitors, images are so detailed, accurate and natural that they will take your breath away. With the highest brightness level of 370 cd/?, the picture quality is more vivid and brilliantly clear.
  • Powerful multitasking features for maximum productivity
    PBP: Picture-by-Picture lets you view 2 different input sources on one screen while maintaining the picture quality of the original source. PIP 2.0: Multitask while you watch a variety of content, thanks to support for even more inputs with Picture-in-Picture 2.0. Resize the second picture to cover up to 25% of the screen and position it anywhere you please, and even control the sound settings with ease.
  • Enhanced connectivity with a triple interface
    The UE590 features a hardware interface with useful and advanced connections to maximize your gaming experience. It provides seamless connectivity with your PC and AV equipment with DisplayPort 1.2 and 2 different HDMI ports making it the perfect partner for your game console as well as your PC.
  • Sophisticated design in matte black & T-shaped stand with a metallic touch
    Sophisticated design: With thoughtful design and engineering, the UE590 is much more than a monitor with stunning looks - it's carefully designed to keep the focus on your content viewing pleasure. It comes with a stunning matte black body framed perfectly by a narrow bezel with a metallic rim, elevated by a T-shaped stand with a matching metallic touch. With support for VESA 75 x 75, you can easily mount it on any wall. Easily and smoothly tilt the screen forward 20° and backwards 2° for comfortable viewing.
  • Easy on the eyes for a more comfortable viewing experience
    Eye saver mode: unlike other colors emitted from screens, blue light wavelengths have a more stimulating effect on the retina, causing eye fatigue. Eye Saver Mode optimizes your viewing comfort by smartly reducing blue light emissions at the touch of a button. Flicker Free: Flicker Free technology reduces screen flickering for a more comfortable viewing experience.
Samsung U28E590D - UD590 Series - LED monitor - 28"
LED-backlit LCD monitor - 28"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/362974
Energy Class
Class G
Energy Consumption per Year
55 kWh
Power Consumption (On mode)
38 W
Panel Type
TN
Native Resolution
4K UHD (2160p) 3840 x 2160 (DisplayPort: 60 Hz, HDMI1: 30 Hz, HDMI2: 60 Hz)
Pixel Pitch
0.161 mm
Brightness
370 cd/m²
Response Time
1 ms
Colour Support
1 billion colours
Input Connectors
2xHDMI, DisplayPort
Display Position Adjustments
Tilt
Black, shiny
66.09 cm x 18.71 cm x 46.85 cm
5.28 kg
Environmental Standards
ENERGY STAR Qualified
ISO 9241-307
Display Type
Energy Class
Class G
55 kWh
Diagonal Size
28"
Panel Type
TN
Native Resolution
Pixel Pitch
0.161 mm
Brightness
370 cd/m²
Colour Support
1 billion colours
Response Time
1 ms
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Power off timer, MagicAngle, MagicBright 3, game mode, Mega Dynamic Contrast Ratio, Eco Saving, Flicker Safe, Mercury free, PIP 2.0, PBP, UHD Upscale
Black, shiny
66.09 cm x 18.71 cm x 46.85 cm - with stand
5.28 kg
2 x HDMI (HDCP) , DisplayPort , Headphones
Mechanical
Tilt
1 x HDMI cable , 1 x DisplayPort cable
ISO 9241-307
Power Supply
External
38 W
38 kWh/1000h
Power Consumption Stand by
0.3 Watt
Apple MacOS, Windows 8
Dimensions & Weight Details
With stand - width: 66.09 cm - depth: 18.71 cm - height: 46.85 cm - weight: 5.28 kg , Without stand - width: 66.09 cm - depth: 7.35 cm - height: 38.13 cm
Sustainability Information
ENERGY STAR Certified
