Samsung U28D590P 28" 3840x2160 1ms HDMI Display Port Wide 4k Black Monitor
Quicklinx: 9HMFWS00 Mfr#: LU28D590DS/EN
The Samsung UHD monitor offers PC viewing, gaming and more with ultra HD picture quality. A resolution 4 times higher than Full HD and an incredible 1 billion colors bring images to life with unparalleled realism. A superfast 1-millisecond response time handles even the fastest moving scenes in movies and games, and great connectivity and game mode mean it is equipped for a rich gaming experience. You can do more with multi-linking features like PIP 2.0 and PBP that keep the original source resolution. Thanks to elegant minimal design, there's nothing to distract you from amazing viewing.
  • Discover the detail of stunningly realistic UHD picture quality
    You've never seen a picture this realistic before. Your UHD monitor has an ultra-high resolution that's 4 times greater than Full HD, delivering stunning images that use a staggering 8 million pixels. See your 4k content the way it was meant to be seen, with a new level of lifelike detail that makes you feel like you're really there. Experience the realism of glorious ultra high definition. An image of a peacock is divided in half. On one side, the FHD screen, on the other, 4k UHD screen. Dragging the middle button to the left or right enables more detailed comparison of the quality. The 4k UHD screen depicts a more realistic and detailed image of peacock than the FHD screen.
  • World best-in-class fast response time at 1 ms
    Your Samsung UHD monitor can handle all the excitement of action movies, games and sports easily thanks to a faster response time of 1-millisecond. You can see even the fastest on-screen motion clearly and smoothly without any motion blur, judder or ghosting. There's no lag during gaming, so it won't let you down at a crucial moment. All the details are right there before your eyes in astonishing UHD clarity and realism.
  • Each and every color richly detailed and truly brilliant
    Get richer and more vivid colors that were meant to be seen in 4k. Many monitors only offer you 16.7 million colors, but a Samsung UHD monitor gives you 64 times more - for an incredible 1 billion colors. That means everything you see is accurate, detailed, natural-looking and so vivid that it will take your breath away. There's also a smoother transition between different tones, passing through more shades in between. Let the UHD monitor show you everything that there is to be seen.
  • Sharpen your content with UHD upscaling
    Bring out the best picture quality possible for all your favorite content and make them worthy of your UHD experience. Samsung's technology automatically detects the content's original resolution and improves it with noise reduction and up-conversion to create clearer, sharper images. Thanks to UHD upscaling, it brings all your entertainment and other content up to a UHD-level.
  • Multi-task and watch everything in its true glory
    The Picture-in-Picture 2.0 technology lets you multi-task and watch videos that maintain 100% of the source resolution. Whether it is 1080p, 720p or 480p, PIP 2.0 doesn't downscale contents and maintains the exact same resolution as clear and crisp on its own. It supports resolutions up to Full HD and you can adjust the PIP resolution and position to fit your needs. There's no loss in quality, so you can really have everything you want with no compromises.
  • Use only one UHD monitor to see 2 different contents
    This advanced multitasking technology lets you do things you could never do before. With Picture-by-Picture, you can connect two PCs to the same monitor and see the desktops of both simultaneously on one screen that's divided into two. Thanks to PBP and the UHD resolution size you won't have to worry about losing any of the glorious picture quality and resolution. Plug in your laptop and your desktop and use both easily without needing to keep looking between different monitors - it is all there at a glance.
  • Enhance your gaming experience with just one button
    Get perfect viewing for games with just one touch of a button. Game mode adjusts your monitor's settings instantly to give you an optimized gaming experience. Game mode smartly detects the changes in scenes, enhances the color and alters the screen's contrast to make dark spots darker and light spots lighter so you can see all the action at all times. There is less lag thanks to a faster video response time that ensures that the picture keeps up with action and won't let you down.
  • Versatile connectivity for all your UHD-compatible devices
    Your Samsung UHD monitor is perfect for your game consoles as well as your PC. Thanks to 2 HDMI ports, both your computer and your console can be connected simultaneously, so you don't have to unplug and plug in each time when you want to switch between them. That means less hassle and more time for entertainment. Thanks to DisplayPort connectivity, your monitor is also ready to connect to UHD-compatible devices and content.
  • Minimal design puts immersive UHD viewing at the forefront
    A beautiful UHD picture should be the center of attention, and Samsung's sophisticated minimalist design makes sure it is. With clean lines and a modern look, the sleek Samsung UHD monitor is constructed from high-quality metal materials and has an understated T-shape body that make the picture even more prominent. The tilt function lets you adjust the monitor to the most comfortable level, and it is designed to take up less space, giving minimal distraction for maximum viewing.
Samsung U28D590DS - LED monitor - 28"
LED-backlit LCD monitor - 28"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/362974
Energy Class
Class G
Energy Consumption per Year
54 kWh
Power Consumption (On mode)
37 W
Panel Type
TN
Native Resolution
4K UHD (2160p) 3840 x 2160 (DisplayPort: 60 Hz, HDMI: 30 Hz)
Brightness
370 cd/m²
Contrast Ratio
1000:1
Response Time
1 ms
Colour Support
1 billion colours
Input Connectors
2xHDMI, DisplayPort
Voltage
Metallic silver, matte black
66.09 cm x 6.47 cm x 41 cm
5.05 kg
Environmental Standards
ENERGY STAR Qualified
DDC-2B
Display Type
Energy Class
Class G
54 kWh
Diagonal Size
28"
Panel Type
TN
Native Resolution
Brightness
370 cd/m²
Contrast Ratio
1000:1
Colour Support
1 billion colours
Response Time
1 ms
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Picture in picture, picture by picture, power off timer, MagicAngle, MagicBright 3, Mega Dynamic Contrast Ratio, Eco Saving
66.09 cm x 6.47 cm x 41 cm - without stand
5.05 kg
Headphones , 2 x HDMI , DisplayPort
1 x HDMI cable
DDC-2B
Power Supply
External
Input Voltage
37 W
38 kWh/1000h
Power Consumption Stand by
0.3 Watt
Dimensions & Weight Details
With stand - width: 66.09 cm - depth: 16.94 cm - height: 48.63 cm - weight: 5.65 kg , Without stand - width: 66.09 cm - depth: 6.47 cm - height: 41 cm - weight: 5.05 kg
Sustainability Information
ENERGY STAR Certified
