- TSST TS006BA - speaker - for portable use - wireless
- Product Type
- Speaker - for portable use
- Speaker Type
- Active
- Continuous Power
- 6 Watt
- Frequency Response
- 150 - 20000 Hz
- Amplifier
- Integrated
- Bluetooth
- Speaker Details
- Speaker - stereo x 2 - 3 Watt - 150 - 20000 Hz - 0.1% THD - active
- Dark grey
- Built-in Decoders
- SBC decoder
- Power Options
- USB charging
- Battery
- Speaker battery rechargeable - Lithium Ion
- 12.4 cm x 2.5 cm x 6.8 cm
- 187 g
- Product Type
- Enclosure Colour
- Dark grey
Speaker System
- Speaker Type
- Active
- Continuous Power
- 6 Watt
- 150 - 20000 Hz
- Max Output Level (Max SPL)
- 90 dB
- Amplifier
- Integrated
- Bluetooth 2.1 EDR
- Bluetooth Profiles
- Advanced Audio Distribution Profile (A2DP), Low Complexity Subband Coding (SBC)
- Built-in Decoders
- SBC decoder
- Controls
- Power on/off
Speaker System Details
- Speaker Details
- Speaker - stereo x 2 - 3 Watt - 150 - 20000 Hz CFR - 0.1% THD - active
- Driver Details
- Speaker: 2 x full-range driver - 1.5" - neodymium
- Connector Type
- Audio line-in (mini-phone stereo 3.5 mm)
- Included Accessories
- USB cable, flip cover
- Power Source
- Battery
- Options
- USB charging
- Rechargeable - Lithium Ion
- Capacity (Ah)
- 750 mAh
- Run Time (Up To)
- 10 hour(s)
- 12.4 cm
- 2.5 cm
- 6.8 cm
- 187 g
