Portable, powerful, yet surprisingly simple. Meet The Freestyle - the Samsung Smart TV experience, with no boundaries.
Smart theater-to-go that follows the fun
Booming 360° sound turns any seat into the perfect position. Enjoy an immersive experience at any size while adjusting focus, keystones, and leveling. -
Point and play
The cradle stand provides floor-to-ceiling flexibility with a rotation of 180°. -
Easy set up
Auto-leveling keeps the screen horizontal and prevents distortions, even on a tilted surface. Autofocus ensures a clear picture, and AutoKeystone measures all angles to project at the universal 16:9 ratio. -
Smart entertainment
This projector features far-field voice control for hands-free flexibility. -
360° sound
Immersive and astounding sounds with 360° audio from high-quality speakers ensure an earful, even from across the room. -
External battery
Pack in the power and easily pair the unit with a portable battery. Take the unit for on-the-go entertainment, indoors or out. -
Scale and move the screen
Shrink down the image, move it around, and project. -
Multiple voice assistants
Find all of the favorite shows, turn up the volume, and take control of those connected devices with the built-in voice assistant. -
Full HD resolution
Jump to a different dimension with Full HD resolution; games, movies, and sports are simply sensational.
- Samsung The Freestyle SP-LFF3CLAX - 2nd Generation - DLP projector - portable - 802.11a/b/g/n/ac wireless / AirPlay 2 - white
- DLP projector - 1080p
- White
- Built-in Devices
- Speaker, microphone
- Brightness
- 230 ANSI lumens
- Contrast Ratio
- 100000:1
- Resolution
- Full HD (1920 x 1080)
- Native Aspect Ratio
- 16:9
- Bulb type
- LED
- Bulb life cycle
- Up to 30000 hour(s)
- Video Input
- IEEE 802.11a/b/g/n/ac wireless / AirPlay 2
- Speakers
- Speaker(s) - integrated
- Platform
- SmartThings
- Intelligent Assistant
- Bixby, Alexa
- Power
- AC 100-240 V (50/60 Hz)
- 50 Watt
- 10.24 cm x 9.52 cm x 17.28 cm
- 830 g
- Built-in Devices
- Networking
- Bluetooth 5.2
- Internet Streaming Services
- Smart TV, Samsung TV PLUS
- Enclosure Colour
- White
Projector
- Brightness
- 230 ANSI lumens
- Contrast Ratio
- 100000:1
- Image Size
- 76 cm - 254 cm
- Projection Distance
- 2.654 m
- Throw Ratio
- 1.2:1
- Resolution
- Full HD - Full HD (1920 x 1080)
- 16:9
- Max Sync Rate (V x H)
- 60 Hz
- Bulb type
- LED
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- OSD Languages
- Multilingual
- Hybrid Log-Gamma (HLG), High Dynamic Range (HDR), Pur Color, HDR10+ compatibility, Contrast Enhancer, Movie Mode, Auto Motion Plus, Dolby Digital Plus, Adaptive Sound, integrated web browser, DLNA support, TV Access, Tap View, App Casting, Wi-Fi Direct, Sound Mirroring, instant on, EPG, Auto Power Off, far-field voice interaction, Ambient Mode, 360° speaker, Smart Calibration, Tizen Platform, Enhanced Audio Return Channel (eARC), Anynet Plus, Crystal Engine
Lens
- Keystone Correction Type
- Digital
Video Input
- Video Interfaces
- HDMI
- LAN and Wireless Image Transferring Protocols
- IEEE 802.11ac, AirPlay 2
Speakers
- Integrated
- Output Power / Channel
- 5 Watt
- Speakers
- 2 x mixed channel
- 1 x HDMI - 19 pin micro HDMI Type D , 1 x USB - 24 pin USB-C
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Platform
- SmartThings
- Bixby, Alexa built-in
- Included Accessories
- Remote control, lens cover
- Cables Included
- 1 x USB-C cable
- Power Source
- AC
- Voltage Required
- 50 Watt
- Power Consumption Stand by
- 0.5 Watt
- 10.24 cm
- 9.52 cm
- 17.28 cm
- 830 g
- Shipping Width
- 14 cm
- Shipping Depth
- 13.7 cm
- Shipping Height
- 24.3 cm
- Shipping Weight
- 1.4 kg
- Sound Emission
- 30 dB
