Samsung Tab S7 FE 64GB WiFi - Light Pink
Quicklinx: GD5HWS00 Mfr#: SM-T730NLIAEUA
  • Android
The beauty in simplicity
Enjoy the sleekness of the Galaxy Tab S7 FE 5G in your hands. The simple, unibody design looks refined with the minimal camera housing on the rear, and the slim form factor keeps your grip comfortable.
  • More power to work, more room to play
    Strike the perfect work-life balance with Galaxy Tab S7 FE. An expansive 12.4" screen and dual speakers wow the senses, and the redesigned S Pen feels more like the real thing.
  • Big screen, big experience
    Get closer to the action with an ultra-large display and a 12.4" viewing surface that's easy on the eyes in almost any light. You'll also hear every detail in Dolby Atmos surround sound with dual speakers tuned by AKG.
  • Speeds that move as fast as you do
    Conquer your to-do list, then stream your favorite shows with virtually no lag, thanks to 5G connectivity.
  • Write, draw, click, tap
    Sketch, draw, and collaborate with the included S Pen, featuring a responsive design that feels closer to pen on paper.
  • More space to get work done
    Master multitasking with wireless connectivity. Tab S7 FE expands your PC workstation with a second screen so you can open windows, hand off files, and cast content with a tap.
  • The power to do more
    Power through your day - and then some - on a single charge. Galaxy Tab S7 FE is powered with long battery life, so it won't let you down in the middle of things whether it's an important meeting or your favorite show. When you finally do need to power up, the fast-charging USB-C port gets you back up to speed in a flash, which means more work or play.
  • The speed to move, the space to grow
    With the Qualcomm Octa-core processor, you will enjoy a smooth experience for the entertainment you love most. Coupled with high-storage memory, Galaxy Tab S7 FE lets you save and store what you need to access on a moment's notice.
  • Puts you center stage
    Stay in frame with a landscape view that automatically puts you front and center. And with a 3-mic solution that reduces surrounding noise by 50%, you'll always sound great on video chats.
Samsung Galaxy Tab S7 FE - tablet - Android - 64 GB - 12.4"
Tablet
Operating System
Android
Display
12.4" TFT - 2560 x 1600 - Multi-Touch
Qualcomm Snapdragon 750G (8-core)
Processor Clock Speed
2.2 GHz
Storage
64 GB
RAM
4 GB
User Available Memory
Flash: 46.7 GB
Supported Flash Memory Cards
microSD, microSDHC, microSDXC
Wireless Connectivity
802.11a/b/g/n/ac, Bluetooth 5.0
Rear Camera
8 Megapixel focus: automatic
Front Camera
5 Megapixel
Navigation System
GPS/GLONASS/Galileo/BeiDou
Battery Run Time
Up to 13 hours
18.5 cm x 0.63 cm x 28.48 cm
608 g
Mystic pink
0.366 W/kg (body)
Tablet
Operating System
Android
Display
12.4" TFT
Resolution
2560 x 1600
Colour Depth
16 million colours
Touchscreen
Multi-Touch
Image Aspect Ratio
16:10
2.2 GHz
Number of Cores
8-core
Storage
64 GB
RAM
4 GB
Flash: 46.7 GB
Max Supported Capacity
1 TB
Communications
Security Protocols & Features
Wi-Fi Direct
Bluetooth Profiles
Hands-Free Profile (HFP), Headset Profile (HSP), Object Push Profile (OPP), Personal Area Networking Profile (PAN), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP), Human Interface Device Profile (HID), Phonebook Access Profile (PBAP), Message Access Profile (MAP), HID Over GATT Profile (HOGP)
Rear Camera
Sensor Resolution
8 Megapixel
Focus Adjustment
Automatic
Video Resolutions
1920 x 1080 (1080p) at 30 fps
Front Camera
Sensor Resolution
5 Megapixel
Navigation System
Receiver
Multimedia
Supported Digital Audio Standards
WAV, AAC, AMR, MP3, FLAC, XMF, OGG, MIDI, M4A, MXMF, OGA, 3GA, AWB, IMY, RTTTL, RTX, OTA, MID
Supported Digital Video Standards
MPEG-4, AVI, MKV, 3GP, FLV, 3G2, M4V, WEBM
Audio
3 microphones, stereo speakers
Input Device
S Pen
Software
Preloaded Software
Samsung Smart Switch
Expansion and Connectivity
Expansion Slots
1 x microSDXC
1 x USB-C 3.2 Gen 1
10090 mAh
Run Time
Up to 13 hours
Run Time Details
Web browsing over Wi-Fi: up to 12 hour(s) , Video playback: up to 13 hour(s) , Audio playback: up to 201 hour(s)
Mystic pink
Sensors
Accelerometer, ambient light sensor, gyro sensor, hall sensor, geomagnetic sensor
MU-MIMO technology, fast charging, tuned by AKG speakers, Samsung DeX
0.366 W/kg (body)
18.5 cm
0.63 cm
28.48 cm
608 g
