The beauty in simplicity
Enjoy the sleekness of the Galaxy Tab S7 FE 5G in your hands. The simple, unibody design looks refined with the minimal camera housing on the rear, and the slim form factor keeps your grip comfortable.
More power to work, more room to play
Strike the perfect work-life balance with Galaxy Tab S7 FE. An expansive 12.4" screen and dual speakers wow the senses, and the redesigned S Pen feels more like the real thing. -
Big screen, big experience
Get closer to the action with an ultra-large display and a 12.4" viewing surface that's easy on the eyes in almost any light. You'll also hear every detail in Dolby Atmos surround sound with dual speakers tuned by AKG. -
Speeds that move as fast as you do
Conquer your to-do list, then stream your favorite shows with virtually no lag, thanks to 5G connectivity. -
Write, draw, click, tap
Sketch, draw, and collaborate with the included S Pen, featuring a responsive design that feels closer to pen on paper. -
More space to get work done
Master multitasking with wireless connectivity. Tab S7 FE expands your PC workstation with a second screen so you can open windows, hand off files, and cast content with a tap. -
The power to do more
Power through your day - and then some - on a single charge. Galaxy Tab S7 FE is powered with long battery life, so it won't let you down in the middle of things whether it's an important meeting or your favorite show. When you finally do need to power up, the fast-charging USB-C port gets you back up to speed in a flash, which means more work or play. -
The speed to move, the space to grow
With the Qualcomm Octa-core processor, you will enjoy a smooth experience for the entertainment you love most. Coupled with high-storage memory, Galaxy Tab S7 FE lets you save and store what you need to access on a moment's notice. -
Puts you center stage
Stay in frame with a landscape view that automatically puts you front and center. And with a 3-mic solution that reduces surrounding noise by 50%, you'll always sound great on video chats.
- Samsung Galaxy Tab S7 FE - tablet - Android - 128 GB - 12.4"
- Product Type
- Tablet
- Operating System
- Android
- Display
- 12.4" TFT - 2560 x 1600 - Multi-Touch
- Processor
- Qualcomm Snapdragon 750G (8-core)
- Processor Clock Speed
- 2.2 GHz
- Storage
- 128 GB
- RAM
- 6 GB
- User Available Memory
- Flash: 105.7 GB
- Supported Flash Memory Cards
- microSD, microSDHC, microSDXC
- Wireless Connectivity
- 802.11a/b/g/n/ac, Bluetooth 5.0
- Rear Camera
- 8 Megapixel focus: automatic
- Front Camera
- 5 Megapixel
- Navigation System
- GPS/GLONASS/Galileo/BeiDou
- Battery Run Time
- Up to 13 hours
- 18.5 cm x 0.63 cm x 28.48 cm
- 608 g
- Mystic green
- Specific Absorption Rate (SAR)
- 0.366 W/kg (body)
- 2-year warranty
- Product Type
- Tablet
- Operating System
- Android
Display
- 12.4" TFT
- Resolution
- 2560 x 1600
- Colour Depth
- 16 million colours
- Touchscreen
- Multi-Touch
- Image Aspect Ratio
- 16:10
- Processor
- 2.2 GHz
- Number of Cores
- 8-core
- Storage
- 128 GB
- RAM
- 6 GB
- Flash: 105.7 GB
- Max Supported Capacity
- 1 TB
Communications
- Wi-Fi Direct
- Bluetooth Profiles
- Hands-Free Profile (HFP), Headset Profile (HSP), Object Push Profile (OPP), Personal Area Networking Profile (PAN), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP), Human Interface Device Profile (HID), Phonebook Access Profile (PBAP), Message Access Profile (MAP), HID Over GATT Profile (HOGP)
Rear Camera
- Sensor Resolution
- 8 Megapixel
- Focus Adjustment
- Automatic
- Video Resolutions
- 1920 x 1080 (1080p) at 30 fps
Front Camera
- Sensor Resolution
- 5 Megapixel
Navigation System
- Receiver
Multimedia
- Supported Digital Audio Standards
- WAV, AAC, AMR, MP3, FLAC, XMF, OGG, MIDI, M4A, MXMF, OGA, 3GA, AWB, IMY, RTTTL, RTX, OTA, MID
- Supported Digital Video Standards
- MPEG-4, AVI, MKV, 3GP, FLV, 3G2, M4V, WEBM
- Audio
- 3 microphones, stereo speakers
Input Device
- S Pen
Software
- Preloaded Software
- Samsung Smart Switch
Expansion and Connectivity
- Expansion Slots
- 1 x microSDXC
- 1 x USB-C 3.2 Gen 1
- Capacity
- 10090 mAh
- Run Time
- Up to 13 hours
- Run Time Details
- Web browsing over Wi-Fi: up to 12 hour(s) , Video playback: up to 13 hour(s) , Audio playback: up to 201 hour(s)
- Mystic green
- Sensors
- Accelerometer, ambient light sensor, gyro sensor, hall sensor, geomagnetic sensor
- MU-MIMO technology, fast charging, tuned by AKG speakers, Samsung DeX
- 0.366 W/kg (body)
- 18.5 cm
- 0.63 cm
- 28.48 cm
- 608 g
- Limited warranty - 2 years
