Samsung Tab S10 Ultra - Grade A
Quicklinx: J5ZCWS00 Mfr#: SM-X926BZAREUB/GRADEA
Operating System: Android 14
Processor: Dimensity 9300+
£582.50 ex VAT
£699.00 inc VAT
The Samsung Galaxy Tab S10 Ultra is designed for an immersive experience with its expansive 14.6-inch Dynamic AMOLED 2X display that offers a native resolution of 2960 x 1848, delivering rich colors and stunning clarity. The advanced 120 Hz refresh rate enhances visual fluidity, making it ideal for gaming, media consumption, and multitasking. With a robust 11200 mAh battery, users can enjoy prolonged usage without frequent recharging. Supporting microSD cards with a maximum capacity of 1.5 TB, this tablet provides ample storage for all multimedia needs, from documents to high-definition videos. Equipped with a powerful MediaTek Dimensity 9300+ processor featuring 8 cores, performance is swift and energy-efficient, ensuring smooth app operations and responsiveness. The tablet also offers impressive camera capabilities, including dual rear cameras with 4K video resolution, along with dual front cameras for video calls and selfies. Its features like water resistance, dust resistance, gesture control, and fast charging make it suitable for everyday use, whether at home or on the go. With the addition of smart connectivity options like Bluetooth 5.3 and Wi-Fi 6, staying connected has never been easier.
Grade A Returned Device
Looking for your next phone or tablet, but want to make your money go further? Try one of our Grade A devices and you’ll find amazing deals on some of the latest and greatest devices.
  • Can be used on any network
  • 12 months warranty
  • Excellent condition, showing up to minimal signs of wear which includes, but not limited to, small/fine scratches and marks.
  • Re-sealed, original packaging
  • Vibrant display
    The 14.6-inch Dynamic AMOLED 2X display features a native resolution of 2960 x 1848, delivering bright, vivid colors and rich detail with an impressive brightness of 930 cd/m2.
  • High-capacity battery
    With a substantial 11200 mAh battery, this tablet supports extended use without frequent recharges, ideal for long streaming or productivity sessions.
  • Versatile camera system
    The Galaxy Tab S10 Ultra includes dual rear cameras with 4K video capability and dual front cameras, providing great versatility for photography and video calls.
  • Robust expansion options
    Featuring a microSD slot that supports cards with a maximum capacity of 1.5 TB, users can easily expand their storage for media and applications.
  • Durable design
    Constructed with armor aluminum and rated IP68 for water and dust resistance, this tablet is designed to withstand everyday challenges, enhancing its longevity.
Samsung Galaxy Tab S10 Ultra - tablet - Android 14 - 256 GB - 14.6" - 3G, 4G, 5G - not specified
Tablet
Operating System
Android 14
Carrier
Not specified
Display
14.6" Dynamic AMOLED 2X - 2960 x 1848 - Multi-Touch
MediaTek Dimensity 9300+ (8-core)
Processor Clock Speed
3.4 GHz
Storage
256 GB
RAM
12 GB
User Available Memory
Flash: 225.1 GB
Supported Flash Memory Cards
microSD, microSDHC, microSDXC
Cellular Technology
3G, 4G, 5G
Cellular Protocols
4G LTE, 5G, 5G Sub-6 Ghz, FDD LTE, TDD LTE, UMTS
Wireless Connectivity
Bluetooth 5.3, 802.11a/b/g/n/ac/ax/be
Rear Camera
13 Megapixel - wide-angle lens focus: automatic
Second Rear Camera
8 Megapixel
Front Camera
12 Megapixel
Second Front Camera
12 Megapixel
Navigation System
GPS/GLONASS/Galileo/BeiDou/QZSS
Battery Run Time
Up to 16 hours
32.64 cm x 0.54 cm x 20.86 cm
723 g
Moonstone grey
0.937 W/kg (body)
Tablet
Operating System
Android 14
Carrier
Not specified
Display
Resolution
2960 x 1848
Colour Depth
16 million colours
Touchscreen
Multi-Touch
Image Aspect Ratio
16:10
Image Brightness
930 cd/m²
Anti-reflective, 120 Hz refresh rate, SmartThings App Support
3.4 GHz
Number of Cores
8-core
Storage
256 GB
RAM
12 GB
Flash: 225.1 GB
Max Supported Capacity
1.5 TB
Communications
SIM Card Type
Electronic SIM card (e-SIM), nano SIM
Cellular Technology
3G, 4G, 5G
Cellular Protocols
Band
GSM 850/900/1800/1900 / UMTS 850/900/AWS/1900/2100 / LTE 1800/2600 / LTE B1/B2/B3/B4/B5/B7/B8/B12/B13/B17/B20/B25/B26/B28/B32/B66/B38/B39/B40/B41 / 5G N1/N2/N3/N5/N7/N8/N12/N20/N25/N26/N28/N66/N38/N40/N41/N77/N78
Security Protocols & Features
Wi-Fi Direct, MIMO technology
Bluetooth Profiles
Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP), Human Interface Device Profile (HID), HID Over GATT Profile (HOGP), Object Push Profile (OPP), Personal Area Networking Profile (PAN), Public Broadcast Profile (PBP), Telephony and Media Audio Profile (TMAP)
Rear Camera
Sensor Resolution
13 Megapixel
Focus Adjustment
Automatic
Lens Type
Wide-angle lens
Light Source
Flash
Video Resolutions
3840 x 2160 (4K) at 30 fps
Second Rear Camera
Sensor Resolution
8 Megapixel
Lens Type
Ultra wide-angle lens
Front Camera
Sensor Resolution
12 Megapixel
Lens Type
Video Resolutions
3840 x 2160 (4K)
Second Front Camera
Sensor Resolution
12 Megapixel
Wide-angle lens
Navigation System
Receiver
Multimedia
Supported Digital Audio Standards
MP3, M4A, 3GA, AAC, OGG, OGA, WAV, AMR, AWB, FLAC, MID, MIDI, XMF, MXMF, IMY, RTTTL, RTX, OTA
Supported Digital Video Standards
MPEG-4, M4V, 3GP, 3G2, AVI, FLV, MKV, WEBM
Audio
Microphones, four speakers
Input Device
S Pen
Software
Preloaded Software
Samsung Smart Switch
Expansion and Connectivity
Expansion Slots
1 x microSDXC
1 x USB-C 3.2 Gen 1
11200 mAh
Run Time
Up to 16 hours
Run Time Details
Web browsing over Wi-Fi: up to 10 hour(s) , Web browsing over 4G: up to 10 hour(s) , Video playback: up to 16 hour(s)
Battery Endurance per Cycle
5118 min
Battery Endurance in Cycles
2000
Moonstone grey
Case Material
Armour aluminium
Sensors
Accelerometer, gyro sensor, hall sensor, light sensor, geomagnetic sensor
Vision Booster, vapor chamber cooling system, water-resistant, dust-resistant, fast charging, gesture control, fingerprint lock
Ejection pin
USB-C to USB-C cable
IEC 60529 IP68
0.937 W/kg (body)
Repairability Class
Class C
Repeated Free Fall Reliability Class
Class E
Ingress Protection Rating
IP68
32.64 cm
0.54 cm
20.86 cm
723 g
Max Depth of Water Resistance
1.5 m
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: J5ZC 050982
Condition: Customer return - item has been used and shows signs of use
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  £402.41
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Brand: Samsung
Price Range Ex VAT: £500 - £750
Stock Status: Used Stock
