The Samsung Galaxy Tab S10 Ultra is designed for an immersive experience with its expansive 14.6-inch Dynamic AMOLED 2X display that offers a native resolution of 2960 x 1848, delivering rich colors and stunning clarity. The advanced 120 Hz refresh rate enhances visual fluidity, making it ideal for gaming, media consumption, and multitasking. With a robust 11200 mAh battery, users can enjoy prolonged usage without frequent recharging. Supporting microSD cards with a maximum capacity of 1.5 TB, this tablet provides ample storage for all multimedia needs, from documents to high-definition videos. Equipped with a powerful MediaTek Dimensity 9300+ processor featuring 8 cores, performance is swift and energy-efficient, ensuring smooth app operations and responsiveness. The tablet also offers impressive camera capabilities, including dual rear cameras with 4K video resolution, along with dual front cameras for video calls and selfies. Its features like water resistance, dust resistance, gesture control, and fast charging make it suitable for everyday use, whether at home or on the go. With the addition of smart connectivity options like Bluetooth 5.3 and Wi-Fi 6, staying connected has never been easier.
Grade A Returned Device
Looking for your next phone or tablet, but want to make your money go further? Try one of our Grade A devices and you’ll find amazing deals on some of the latest and greatest devices.
- Can be used on any network
- 12 months warranty
- Excellent condition, showing up to minimal signs of wear which includes, but not limited to, small/fine scratches and marks.
- Re-sealed, original packaging
Vibrant display
The 14.6-inch Dynamic AMOLED 2X display features a native resolution of 2960 x 1848, delivering bright, vivid colors and rich detail with an impressive brightness of 930 cd/m2. -
High-capacity battery
With a substantial 11200 mAh battery, this tablet supports extended use without frequent recharges, ideal for long streaming or productivity sessions. -
Versatile camera system
The Galaxy Tab S10 Ultra includes dual rear cameras with 4K video capability and dual front cameras, providing great versatility for photography and video calls. -
Robust expansion options
Featuring a microSD slot that supports cards with a maximum capacity of 1.5 TB, users can easily expand their storage for media and applications. -
Durable design
Constructed with armor aluminum and rated IP68 for water and dust resistance, this tablet is designed to withstand everyday challenges, enhancing its longevity.
- Samsung Galaxy Tab S10 Ultra - tablet - Android 14 - 256 GB - 14.6" - 3G, 4G, 5G - not specified
- Product Type
- Tablet
- Operating System
- Android 14
- Carrier
- Not specified
- Display
- 14.6" Dynamic AMOLED 2X - 2960 x 1848 - Multi-Touch
- Processor
- MediaTek Dimensity 9300+ (8-core)
- Processor Clock Speed
- 3.4 GHz
- Storage
- 256 GB
- RAM
- 12 GB
- User Available Memory
- Flash: 225.1 GB
- Supported Flash Memory Cards
- microSD, microSDHC, microSDXC
- Cellular Technology
- 3G, 4G, 5G
- Cellular Protocols
- 4G LTE, 5G, 5G Sub-6 Ghz, FDD LTE, TDD LTE, UMTS
- Wireless Connectivity
- Bluetooth 5.3, 802.11a/b/g/n/ac/ax/be
- Rear Camera
- 13 Megapixel - wide-angle lens focus: automatic
- Second Rear Camera
- 8 Megapixel
- Front Camera
- 12 Megapixel
- Second Front Camera
- 12 Megapixel
- Navigation System
- GPS/GLONASS/Galileo/BeiDou/QZSS
- Battery Run Time
- Up to 16 hours
- 32.64 cm x 0.54 cm x 20.86 cm
- 723 g
- Moonstone grey
- Specific Absorption Rate (SAR)
- 0.937 W/kg (body)
- Product Type
- Tablet
- Operating System
- Android 14
- Carrier
- Not specified
Display
- Resolution
- 2960 x 1848
- Colour Depth
- 16 million colours
- Touchscreen
- Multi-Touch
- Image Aspect Ratio
- 16:10
- Image Brightness
- 930 cd/m²
- Anti-reflective, 120 Hz refresh rate, SmartThings App Support
- Processor
- 3.4 GHz
- Number of Cores
- 8-core
- Storage
- 256 GB
- RAM
- 12 GB
- Flash: 225.1 GB
- Max Supported Capacity
- 1.5 TB
Communications
- SIM Card Type
- Electronic SIM card (e-SIM), nano SIM
- 3G, 4G, 5G
- Band
- GSM 850/900/1800/1900 / UMTS 850/900/AWS/1900/2100 / LTE 1800/2600 / LTE B1/B2/B3/B4/B5/B7/B8/B12/B13/B17/B20/B25/B26/B28/B32/B66/B38/B39/B40/B41 / 5G N1/N2/N3/N5/N7/N8/N12/N20/N25/N26/N28/N66/N38/N40/N41/N77/N78
- Wi-Fi Direct, MIMO technology
- Bluetooth Profiles
- Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP), Human Interface Device Profile (HID), HID Over GATT Profile (HOGP), Object Push Profile (OPP), Personal Area Networking Profile (PAN), Public Broadcast Profile (PBP), Telephony and Media Audio Profile (TMAP)
Rear Camera
- Sensor Resolution
- 13 Megapixel
- Focus Adjustment
- Automatic
- Lens Type
- Wide-angle lens
- Light Source
- Flash
- Video Resolutions
- 3840 x 2160 (4K) at 30 fps
Second Rear Camera
- Sensor Resolution
- 8 Megapixel
- Lens Type
- Ultra wide-angle lens
Front Camera
- Sensor Resolution
- 12 Megapixel
- Lens Type
- Video Resolutions
- 3840 x 2160 (4K)
Second Front Camera
- Sensor Resolution
- 12 Megapixel
- Wide-angle lens
Navigation System
- Receiver
Multimedia
- Supported Digital Audio Standards
- MP3, M4A, 3GA, AAC, OGG, OGA, WAV, AMR, AWB, FLAC, MID, MIDI, XMF, MXMF, IMY, RTTTL, RTX, OTA
- Supported Digital Video Standards
- MPEG-4, M4V, 3GP, 3G2, AVI, FLV, MKV, WEBM
- Audio
- Microphones, four speakers
Input Device
- S Pen
Software
- Preloaded Software
- Samsung Smart Switch
Expansion and Connectivity
- Expansion Slots
- 1 x microSDXC
- 1 x USB-C 3.2 Gen 1
- Capacity
- 11200 mAh
- Run Time
- Up to 16 hours
- Run Time Details
- Web browsing over Wi-Fi: up to 10 hour(s) , Web browsing over 4G: up to 10 hour(s) , Video playback: up to 16 hour(s)
- Battery Endurance per Cycle
- 5118 min
- Battery Endurance in Cycles
- 2000
- Moonstone grey
- Case Material
- Armour aluminium
- Sensors
- Accelerometer, gyro sensor, hall sensor, light sensor, geomagnetic sensor
- Vision Booster, vapor chamber cooling system, water-resistant, dust-resistant, fast charging, gesture control, fingerprint lock
- Included Accessories
- Ejection pin
- Cables Included
- USB-C to USB-C cable
- IEC 60529 IP68
- 0.937 W/kg (body)
- Repairability Class
- Class C
- Repeated Free Fall Reliability Class
- Class E
- Ingress Protection Rating
- IP68
- 32.64 cm
- 0.54 cm
- 20.86 cm
- 723 g
- Max Depth of Water Resistance
- 1.5 m
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
J5ZC 050982 Condition: Customer return - item has been used and shows signs of use |
£402.41 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
