Galaxy Tab Active4 Pro helps your crew stay on task. It weathers drops, spills and extreme heat/cold. Its touchscreen works even if you wear wet gloves. Its long-lasting battery is swappable.
Durability you can rely on
Work confidently in tough workplaces such as warehouses and factories knowing that its MIL-STD-810H rating will stand up against shock, vibration, dust, sand and drops on concrete up to 1 m3. And its IP68 rating will protect from water spray and complete submersion. -
For hours of uninterrupted work
Galaxy Tab Active 4 Pro's long-lasting battery goes long into the workday. Power up quickly with a fast charger and convenient pogo pins. -
No batteries required
Keep going with no battery mode, which directs power to the tablet without relying on the battery. Perfect for long shifts and vehicle workers. -
Designed to withstand the elements
Keep your team moving - rain or shine - with a responsive touchscreen that works well in wet or damp conditions - even with gloves on. -
A fast, reliable connection everywhere
Knock out tasks in record time with high-speed connectivity, courtesy of faster 5G and Wi-Fi 6 wireless data networks. -
Stay protected and productive
Rest easy knowing Knox security protects your device, your data and your clients' data from the chip up. -
Everything you need in one package
Feel confident knowing you've purchased a quality device - Galaxy Tab Active 4 Pro is an Android enterprise recommended product that delivers verified enterprise grade features and expertise. -
Your personal info under your control
Privacy dashboard puts you in full control of which apps have access to your mic, camera, location and other data, as part of the commitment to ensuring your security. -
Keep work and personal data separate
Work Profile lets IT keep business data secure while giving users the freedom and privacy to use personal apps and content.
- Samsung Galaxy Tab Active4 Pro - tablet - Android - 128 GB - 10.1" - 3G, 4G, 5G
- Product Type
- Tablet - rugged
- Operating System
- Android
- Display
- 10.1" TFT - 1920 x 1200 - Multi-Touch
- Processor
- (8-core)
- Processor Clock Speed
- 2.4 GHz
- Storage
- 128 GB
- RAM
- 6 GB
- User Available Memory
- Flash: 104.6 GB
- Supported Flash Memory Cards
- microSD, microSDHC, microSDXC
- Cellular Technology
- 3G, 4G, 5G
- Cellular Protocols
- GSM, UMTS, FDD LTE, TDD LTE, 5G NR
- Wireless Connectivity
- NFC, 802.11a/b/g/n/ac/ax, Bluetooth 5.2
- Rear Camera
- 13 Megapixel focus: automatic
- Front Camera
- 8 Megapixel
- Navigation System
- GPS/GLONASS/Galileo/BeiDou/QZSS
- Security Devices
- Fingerprint reader, face recognition
- Battery Run Time
- Up to 16 hours
- 17.02 cm x 1.02 cm x 24.29 cm
- 674 g
- Black
- Specific Absorption Rate (SAR)
- 1.125 W/kg
- 3-year warranty
- Product Type
- Tablet - rugged
- Operating System
- Android
Display
- 10.1" TFT
- Resolution
- 1920 x 1200
- Colour Depth
- 16 million colours
- Touchscreen
- Multi-Touch
- Corning Gorilla glass 5
- 2.4 GHz
- Number of Cores
- 8-core
- Storage
- 128 GB
- RAM
- 6 GB
- Flash: 104.6 GB
- Max Supported Capacity
- 1 TB
Communications
- 3G, 4G, 5G
- Wi-Fi Direct
- Bluetooth Profiles
- Hands-Free Profile (HFP), Headset Profile (HSP), Object Push Profile (OPP), Personal Area Networking Profile (PAN), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP), Human Interface Device Profile (HID), Phonebook Access Profile (PBAP), Message Access Profile (MAP), HID Over GATT Profile (HOGP)
Rear Camera
- Sensor Resolution
- 13 Megapixel
- Focus Adjustment
- Automatic
- Light Source
- Flash
- Video Resolutions
- 3840 x 2160 (4K) at 30 fps
Front Camera
- Sensor Resolution
- 8 Megapixel
Navigation System
- Receiver
Multimedia
- Supported Digital Audio Standards
- WAV, AAC, AMR, MP3, FLAC, XMF, OGG, MIDI, M4A, MXMF, OGA, 3GA, AWB, IMY, RTTTL, RTX, OTA, MID
- Supported Digital Video Standards
- AVI, MKV, 3GP, FLV, 3G2, M4V, WEBM, MP4
- Audio
- Microphone, speaker
Input Device
- S Pen
- Security Devices
Software
- Preloaded Software
- Samsung Smart Switch
Expansion and Connectivity
- Expansion Slots
- 1 x microSD
- USB-C 3.2 Gen 1 , Headphones mini jack (3.5mm) , POGO pin
- Capacity
- 7600 mAh
- Run Time
- Up to 16 hours
- Talk Time
- 3540 minutes
- Run Time Details
- Web browsing over Wi-Fi: up to 16 hour(s) , Web browsing over 4G: up to 16 hour(s) , Video playback: up to 16 hour(s) , Talk time: up to 3540 min
- Black
- Sensors
- Accelerometer, proximity sensor, gyro sensor, hall sensor, grip sensor, RGB sensor, geomagnetic sensor
- Water-resistant, dust-resistant, MIMO technology, scratch-resistant, Samsung DeX
- Included Accessories
- S Pen
- IPX5, IPX8, IP6X, IEC 60529, IP68 Certified, MIL-STD-810H, IEC 61960
- 1.125 W/kg
- 17.02 cm
- 1.02 cm
- 24.29 cm
- 674 g
- Limited warranty - 3 years
- Max Depth of Water Resistance
- 1.5 m
