Meet the Galaxy Tab A7 Lite, the tablet that's made to be shared. With a compact screen, sturdy metal frame, powerful performance and plenty of storage, your whole family will love it.
Light and portable
With its compact screen and slim design Galaxy Tab A7 Lite is perfectly sized for entertainment on the go. -
Sturdy metal frame for lasting protection
Galaxy Tab A7 Lite features an upgraded metal frame that helps protect against everyday hiccups. -
Performance that won't let you down
Enjoy super-smooth streaming on your tablet with minimal interruptions and expandable storage for all your important photos, videos and apps.
- Samsung Galaxy Tab A7 Lite - tablet - Android - 32 GB - 8.7" - 3G, 4G
- Product Type
- Tablet
- Operating System
- Android
- Display
- 8.7" TFT - 1340 x 800 - Multi-Touch
- Processor
- (8-core)
- Processor Clock Speed
- 2.3 GHz
- Storage
- 32 GB
- RAM
- 3 GB
- User Available Memory
- Flash: 19.5 GB
- Supported Flash Memory Cards
- microSD, microSDHC, microSDXC
- Cellular Technology
- 3G, 4G
- Cellular Protocols
- GSM, UMTS, FDD LTE, TDD LTE
- Wireless Connectivity
- 802.11a/b/g/n/ac, Bluetooth 5.0
- Rear Camera
- 8 Megapixel focus: automatic
- Front Camera
- 2 Megapixel
- Navigation System
- GPS/GLONASS/Galileo/BeiDou
- 12.47 cm x 0.8 cm x 21.25 cm
- 371 g
- Grey
- Specific Absorption Rate (SAR)
- 0.64 W/kg (head) , 0.99 W/kg (body)
- 2-year warranty
- Product Type
- Tablet
- Operating System
- Android
Display
- 8.7" TFT
- Resolution
- 1340 x 800
- Colour Depth
- 16 million colours
- Touchscreen
- Multi-Touch
- 2.3 GHz
- Number of Cores
- 8-core
- Storage
- 32 GB
- RAM
- 3 GB
- Flash: 19.5 GB
- Max Supported Capacity
- 1 TB
Communications
- 3G, 4G
- Band
- GSM 850/900/1800/1900 / UMTS 850/900/AWS/1900/2100 / LTE 700/800/850/900/AWS/AWS-3/1800/1900/2100/2300/2600
- Wi-Fi Direct
- Bluetooth Profiles
- Hands-Free Profile (HFP), Headset Profile (HSP), Object Push Profile (OPP), Personal Area Networking Profile (PAN), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP), Human Interface Device Profile (HID), Phonebook Access Profile (PBAP), Message Access Profile (MAP), HID Over GATT Profile (HOGP)
Rear Camera
- Sensor Resolution
- 8 Megapixel
- Focus Adjustment
- Automatic
- Lens Aperture
- F/2.0
- Video Resolutions
- 1920 x 1080 (1080p) at 30 fps
Front Camera
- Sensor Resolution
- 2 Megapixel
- Lens Aperture
- F/2.2
Navigation System
- Receiver
Multimedia
- Supported Digital Audio Standards
- WAV, AAC, AMR, MP3, FLAC, XMF, OGG, MIDI, M4A, MXMF, OGA, 3GA, AWB, IMY, RTTTL, RTX, OTA, MID
- Supported Digital Video Standards
- MPEG-4, AVI, MKV, 3GP, FLV, 3G2, M4V, WEBM
- Audio
- Microphone, stereo speakers
Software
- Preloaded Software
- Samsung KNOX, Samsung Smart Switch
Expansion and Connectivity
- Expansion Slots
- 1 x microSDXC
- USB-C/USB 2.0 , Headphones mini jack (3.5mm)
- Technology
- Lithium Ion
- Capacity
- 5100 mAh
- Grey
- Case Material
- Metal
- Sensors
- Accelerometer, geomagnetic sensor, light sensor
- Fast charging
- 12.47 cm
- 0.8 cm
- 21.25 cm
- 371 g
- Limited warranty - 2 years
