Samsung T7 MU-PC4T0T - SSD - 4 TB - USB 3.2 Gen 2
Quicklinx: HXK6WS00 Mfr#: MU-PC4T0T/WW
Hurry, only 1 left in stock!
£473.32 ex VAT
£567.98 inc VAT
The Samsung T7 external hard drive combines speed, security, and durability in a sleek, portable package. With a 10.0 Gbps USB 3.2 Gen 2 interface and max data transfer rates of up to 1050 MB/s, it offers rapid file access and transfer speeds, making it ideal for busy professionals and multimedia enthusiasts alike. The 4 TB capacity provides ample space for large files, photos, and videos, ensuring you have all your important data at your fingertips. Security is paramount with the Samsung T7, featuring 256-bit AES encryption and password authentication to protect your data from unauthorized access. Its shock-resistant design and durable aluminum casing mean you can take your data wherever you go without worry. Whether you're at the office, at home, or on the move, the Samsung T7 is the perfect companion for all your storage needs.
  • Rapid transfer speeds
    Experience fast data transfer with the Samsung T7 external hard drive, boasting an impressive interface speed of 10.0 Gbps (USB 3.2 Gen 2). This ensures quick and efficient storage and retrieval of your data, making it perfect for those who value speed in their digital interactions.
  • Robust security
    Keep your data secure with the Samsung T7's built-in 256-bit AES encryption and password authentication features. Whether you're storing sensitive documents or precious memories, you can rest assured that your information is safe from unauthorized access.
  • Durable design
    Designed to withstand the rigors of daily use, the Samsung T7 features a shock-resistant structure and a sturdy aluminum casing. This portable external hard drive is built to last, providing reliable storage wherever you go.
Solid state drive - external (portable)
4 TB
Hardware Encryption
Encryption Algorithm
256-bit AES
USB 3.2 Gen 2 - USB-C
Data Transfer Rate
10.0 Gbps (USB 3.2 Gen2)
Shock resistant, password authentication, USB Attached SCSI Protocol (UASP) compliant, NVM Express (NVMe), 256-bit AES
Power Source
USB bus
Enclosure Colour
Grey
85 mm x 8 mm x 57 mm
72 g
3-year warranty
4 TB
Hardware Encryption
256-bit AES
USB 3.2 Gen 2
85 mm
8 mm
57 mm
72 g
Performance
Interface Transfer Rate
Max Data Transfer Rate
1050 MB/s
Internal Data Rate
1050 MBps (read) / 1000 MBps (write)
Expansion & Connectivity
1 x USB 3.2 Gen 2 - 24 pin USB-C
Power Source
USB bus
Software Included
Samsung Magician Software
1 x USB-C cable , 1 x USB-C to USB-A cable
UL, TUV, VCCI, BSMI, CB, IC, FCC, KC, RoHS Phase 2, EAC, RCM, BIS, UKCA
Enclosure Colour
Grey
Limited warranty - 3 years
60 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
85 °C
5 - 95% (non-condensing)
Shock Tolerance (non-operating)
1500 g @ 0.5 ms
Vibration Tolerance (operating)
20 g @ 20-2000 Hz
Brand: Samsung
