Light and pocket-sized, the Portable SSD T7 both delivers fast speeds and safeguards data for an easy way to store and transfer large files. Experience everyday high performance in your work and play with the T7.
Transfer in a flash
Transfer massive files within seconds with the incredible speed of USB 3.2 Gen 2 on the T7. The embedded PCIe NVMe technology facilitates sequential read/write speeds of up to 1,050/1,000 MB/s, respectively, making the T7 almost twice as fast as the previous T5 model. -
Built strong and secure
SSD stands for Solid State Drive, which means it's built with no moving parts. The hardware can be secured with an AES 256-bit encrypted password and is encased in a sturdy metal body that keeps data intact from falls of up to 2 meters. -
Sophisticated thermal solution
Use T7 without worrying about overheating. The T7's advanced thermal solution uses ePCM technology and the Dynamic Thermal Guard to withstand and control heat, so the compact SSD stays at an optimal temperature even at fast speeds. -
Sleek and compact style
Pocket-sized and slim, the lightweight body comes standard on the T7. Roughly the size of a credit card and weighing in at 58 grams, the solid aluminum unibody construction fits comfortably in the palm of your hand. -
Multi-device compatibility
Access your files anytime, anywhere. The T7 is compatible with PC, Mac, Android devices, gaming consoles, and more. Included in the box are USB Type C-to-C and Type C-to-A cables for added convenience. -
Management software
The T7 comes embedded with upgraded software for PCs and Macs to help you set up a password and get the latest firmware updates. You can also download the mobile app for Android smartphones and tablets.
- Samsung T7 MU-PC500R - SSD - 500 GB - USB 3.2 Gen 2
- Solid state drive - external (portable)
- Capacity
- 500 GB
- Hardware Encryption
- Encryption Algorithm
- 256-bit AES
- Interface
- USB 3.2 Gen 2 - USB-C
- Data Transfer Rate
- 10.0 Gbps (USB 3.2 Gen2)
- Shock resistant, password authentication, Dynamic Thermal Guard protection, NVM Express (NVMe), 256-bit AES
- Power Source
- USB bus
- Enclosure Colour
- Red metallic
- 85 mm x 8 mm x 57 mm
- 58 g
- 3-year warranty
- Capacity
- 500 GB
- 256-bit AES
- Interface
- USB 3.2 Gen 2
- 85 mm
- 8 mm
- 57 mm
- 58 g
Performance
- Interface Transfer Rate
- Max Data Transfer Rate
- 1050 MB/s
- Internal Data Rate
- 1050 MBps (read) / 1000 MBps (write)
Expansion & Connectivity
- 1 x USB 3.2 Gen 2 - 24 pin USB-C
- Power Source
- USB bus
- OS Required
- Microsoft Windows 7 or later, Apple MacOS X 10.10.x or later, Android 5.1 (Lollipop) or later
- Cables Included
- 1 x USB-C cable , 1 x USB-C to USB-A cable
- UL, TUV, VCCI, C-Tick, BSMI, CB, IC, FCC, KC, RoHS2, EAC, UASP (USB Attached SCSI Protocol)
- Enclosure Colour
- Red metallic
- Limited warranty - 3 years
