Samsung T5 Evo SSD 2TB USB 3.2 Gen 1
Quicklinx: HXZ7WS00 Mfr#: MU-PH2T0S/EU
£117.88 ex VAT
£141.45 inc VAT
The Samsung T5 Evo stands out in the realm of portable hard drives, offering a blend of performance, durability, and security. With a generous 2 TB capacity, it meets the storage needs of most users, allowing for the storage of large files and extensive media libraries. Its portable design, combined with a USB bus power source, makes it an excellent choice for professionals and students alike who require their data on-the-move.
High-speed data transfers are a hallmark of the Samsung T5 Evo, thanks to its USB 3.2 Gen 1 interface and support for the USB Attached SCSI Protocol (UASP), ensuring efficient file access and transfer rates of up to 460 MB/s. Moreover, the drive's Dynamic Thermal Guard protection and shock-resistant features ensure your data is protected against physical damage, while 256-bit AES hardware encryption keeps your data secure from unauthorized access. Whether for work, study, or entertainment, the Samsung T5 Evo is a reliable storage solution that offers performance and peace of mind.
  • Robust design
    Equipped with Dynamic Thermal Guard protection and a shock-resistant build, the Samsung T5 Evo ensures your data is safe even in demanding conditions. Its durable exterior is designed to withstand the rigors of daily use, making it suitable for professionals on-the-go
  • High-speed connectivity
    Featuring a USB 3.2 Gen 1 interface with a USB-C port, the Samsung T5 Evo offers an interface speed of up to 5.0 Gbps. Coupled with the USB Attached SCSI Protocol (UASP) compliance, it ensures high-speed data transfers, making it suitable for transferring large files without the wait
  • Secure data encryption
    With built-in 256-bit AES hardware encryption, the Samsung T5 Evo provides high-level security for your data. This feature allows you to protect your personal and sensitive information from unauthorized access, giving you peace of mind
Samsung T5 Evo MU-PH2T0S - SSD - 2 TB - USB 3.2 Gen 1
Solid state drive - external (portable)
2 TB
Hardware Encryption
Encryption Algorithm
256-bit AES
USB 3.2 Gen 1 - USB-C
Data Transfer Rate
5.0 Gbps (USB 3.2 Gen 1)
Shock resistant, USB Attached SCSI Protocol (UASP) compliant, Dynamic Thermal Guard protection
Power Source
USB bus
Enclosure Colour
4 cm x 1.7 cm x 9.5 cm
102 g
3-year warranty
2 TB
Hardware Encryption
256-bit AES
USB 3.2 Gen 1
4 cm
1.7 cm
9.5 cm
102 g
Performance
Interface Transfer Rate
Max Data Transfer Rate
460 MB/s
Expansion & Connectivity
1 x USB 3.2 Gen 1 - 24 pin USB-C
Power Source
USB bus
Apple MacOS, Microsoft Windows, Android
UL, TUV, VCCI, BSMI, CB, IC, FCC, RoHS2, EAC, RCM, BIS, UKCA
Enclosure Colour
Limited warranty - 3 years
60 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
85 °C
Brand: Samsung
