Samsung T5 Evo MU-PH4T0S - SSD - 4 TB - USB 3.2 Gen 1
Quicklinx: HXK5WS00 Mfr#: MU-PH4T0S/EU
12 In Stock
£219.57 ex VAT
£263.48 inc VAT
The Samsung T5 Evo external hard drive combines high-capacity storage, advanced security features, and durability to meet the needs of demanding data management tasks. With a 4 TB capacity, it offers ample space for all your storage requirements, from large multimedia files to critical backups. The drive's high-speed USB 3.2 Gen 1 interface ensures efficient data transfers at speeds up to 460 MB/s, making it perfect for quick file sharing and backups. Enhanced with Dynamic Thermal Guard protection and a shock-resistant build, the T5 Evo is designed to withstand challenging environments, ensuring your data remains safe and intact. Additionally, the inclusion of 256-bit AES hardware encryption provides an extra layer of security, safeguarding your sensitive information from unauthorized access. Whether for professional or personal use, the Samsung T5 Evo is a reliable choice for those who require high performance, security, and durability in their data storage solutions.
  • Robust durability
    Equipped with Dynamic Thermal Guard protection and a shock-resistant build, the Samsung T5 Evo offers durability, ensuring your data stays safe even in demanding conditions.
  • High-speed transfers
    With an interface speed of 5.0 Gbps (USB 3.2 Gen 1) and a max data transfer rate of 460 MB/s, this external hard drive provides swift and efficient data transfers, making it ideal for quick file sharing and backups.
  • Expansive storage
    Boasting a generous 4 TB capacity, the Samsung T5 Evo meets all your storage needs, allowing you to store vast amounts of data, from high-resolution photos and videos to extensive software libraries, all in one portable device.
  • Secure encryption
    Featuring 256-bit AES hardware encryption, the Samsung T5 Evo ensures your sensitive information is securely stored, giving you peace of mind that your data is protected against unauthorized access.
Solid state drive - external (portable)
4 TB
Hardware Encryption
Encryption Algorithm
256-bit AES
USB 3.2 Gen 1 - USB-C
Data Transfer Rate
Shock resistant, USB Attached SCSI Protocol (UASP) compliant, Dynamic Thermal Guard protection
Power Source
USB bus
Enclosure Colour
4 cm x 1.7 cm x 9.5 cm
102 g
3-year warranty
4 TB
Hardware Encryption
256-bit AES
USB 3.2 Gen 1
4 cm
1.7 cm
9.5 cm
102 g
Performance
Interface Transfer Rate
Max Data Transfer Rate
460 MB/s
Expansion & Connectivity
1 x USB 3.2 Gen 1 - 24 pin USB-C
Power Source
USB bus
Apple MacOS, Microsoft Windows, Android
UL, TUV, VCCI, BSMI, CB, IC, FCC, RoHS2, EAC, RCM, BIS, UKCA
Enclosure Colour
Limited warranty - 3 years
60 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
85 °C
Brand: Samsung
