Samsung T5 1TB Portable SSD - Metallic Red
Quicklinx: F5XXWS00 Mfr#: MU-PA1T0R/EU
Form Factor: 2.5"
Capacity: 1TB, 1TB
Interface: USB 3.1 Gen 2
Type: External hard drive
More than 50 in stock
£133.33 ex VAT
£159.99 inc VAT
The Samsung Portable SSD T5 elevates data transfer speeds to the next level and unleashes an advanced experience in external storage. With a compact and durable design and password protection, the T5 is truly easy to carry and stores data securely.
  • Fast transfer speeds
    With Samsung V-NAND flash memory and a USB 3.1 Gen 2 interface, the T5 provides fast transfer speeds. Transfers and backups of large-sized data, including 4K videos and high-resolution photos, will be much quicker and faster.
  • Metal minimalism
    The top to bottom metal design and rounded unibody fits comfortably in the palm of your hand.
  • Compact and light
    Smaller than the average business card, weighing little and thin. The compact, light and slim, T5 is the perfect portable storage.
  • Solid inside and out
    Do more. Worry less. The T5 has no moving parts and a sturdy metal body, so it can handle drops.
  • Connect with ease
    Connect the T5 to an extensive range of devices from PCs, smartphones and other devices.
Samsung Portable SSD T5 MU-PA1T0 - solid state drive - 1 TB - USB 3.1 Gen 2
Solid state drive - external (portable) - shock resistant, password authentication, USB Attached SCSI Protocol (UASP) compliant, V-NAND Technology
1 TB
Hardware Encryption
Encryption Algorithm
256-bit AES
USB 3.1 Gen 2 - USB-C
Data Transfer Rate
10.0 Gbps (USB 3.1)
Shock resistant, password authentication, USB Attached SCSI Protocol (UASP) compliant, V-NAND Technology, 256-bit AES
Power Source
USB bus
Enclosure Colour
Red
7.4 cm x 1.05 cm x 5.73 cm
51 g
3-year warranty
1 TB
Hardware Encryption
256-bit AES
USB 3.1 Gen 2
7.4 cm
1.05 cm
5.73 cm
51 g
Performance
Interface Transfer Rate
10.0 Gbps (USB 3.1)
Max Data Transfer Rate
540 MB/s
Expansion & Connectivity
1 x USB 3.1 Gen 2 - 24 pin USB-C
Power Source
USB bus
Microsoft Windows 7 or later, Android 4.4 (KitKat) or later, Apple MacOS X 10.9.x or later
UL, TUV, VCCI, C-Tick, BSMI, CB, IC, FCC, KC, RoHS2, EAC, UASP (USB Attached SCSI Protocol)
Enclosure Colour
Red
Limited warranty - 3 years
Form Factor: 2.5"
Capacity: 1TB
Capacity: 1TB
Brand: Samsung
Price Range Ex VAT: 100 - 150
