Samsung SyncMaster S27A850D - LCD display - TFT - LED backlight - 27" - 2560 x 1440 - matte black
Quicklinx: 7TW3WS00 Mfr#: LS27A850DS/EN
Reinvent your desk with the Samsung SA850 LED Monitor. It brings together the very best monitor features like the outstanding LED clarity and WQHD screen resolution, to deliver a totally professional experience. It offers the support needed for all your content, like your videos and pictures, while also providing optimised viewing with the convenient Wide Angle Viewing feature. So, why not make the move to the LED monitor that is raising the standards and expectations for everyone.
  • Picture perfect, natural-looking images
    Whether it's video from an HD camcorder or photos from your digital camera, sRGB support makes sure that nature looks just as natural on your Samsung Monitor as it did when you shot it or filmed it. No matter what digital device the image was captured on, it's as picture perfect on screen as Mother Nature intended it to be. So you can view, edit, and save images in their original format with no picture quality degradation whatsoever — which translates to 100% pure digital satisfaction.
  • Conserves Energy and Preserves the Environment
    Engineered with the ecologically responsible homeowner in mind, the Samsung monitor reduces power consumption by 40%, making it much more efficient than conventional monitors. By reducing the number of LED and defaulting to standby power, which requires less than 0.3W as opposed to the typical 1W, the Samsung monitor is poised to make a difference. How big a difference? If your monitor saves 120W each day, that's the annual equivalent of eliminating 10.8kg of CO2 emitted from an oil-burning power plant—which produces the same effect as planting four pine trees.
  • See more content with unbelievable screen resolution
    The Samsung SA850 Monitor showcases an astounding WQHD display with 2560 x 1440 pixel resolution, which is four times the resolution of HD (720p). It is perfect for businesses and industries that rely on access to extremely fine monitor detail. The wide screen, which features dual link DVI and display port, allows for more detail to be viewed and is ideal for work places such as hospitals, clinics and studios. The enhanced screen resolution provides greater efficiency and quality, and really is the must-have business tool.
  • See Your Work from the Best Possible Angle
    Provide employees with an optimal viewing experience in the office with the reasonably priced Samsung Business Monitor. While conventional monitors have a viewing angle of 170 degrees horizontally, the Samsung monitor has an extra wide viewing angle of 178 degrees. The additional 8 degrees is particularly useful when sharing on-screen information with one or more coworkers or presenting your ideas to clients. The Samsung Business Monitor has improved its vertical viewing angles by 18 degrees, making it the perfect display for giving presentations in front of a large audience or when viewing other content such as a video.
  • See perfect colours from wherever you sit
    Maximise your viewing experience with Samsung's superior PLS technology (Plane to Line Switching). Regular screens suffer from what is called Colour Shift, which reduces the picture quality and colour when viewed from an acute angle. The SA850, which can cover an amazing 178° viewing angle both vertically and horizontally, boasts a crisp and detailed picture by maintaining true-to-life colour, even when viewed from extreme angels, so the experience is always vivid and brilliant.
Samsung S27A850D - LED monitor - 27"
LED-backlit LCD monitor - 27"
Native Resolution
2560 x 1440
Brightness
300 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
2xDVI-D, DisplayPort
Display Position Adjustments
Height, swivel, tilt
Matte black
64.2 cm x 22.4 cm x 44.2 cm
6.6 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
Plug and Play, DDC-2B
Display Type
Diagonal Size
27"
Native Resolution
2560 x 1440
Brightness
300 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
5 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Picture in picture, power off timer, MagicColor, HDCP, MagicAngle, MagicBright 3, Mega Contrast, Eco Light Sensor, Eco Motion Sensor
Matte black
64.2 cm x 22.4 cm x 44.2 cm - with stand
6.6 kg
DisplayPort , DVI-D (dual link) , 3 x USB 3.0
Mechanical
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm, 100 x 200 mm
Wall mountable
Power Supply
External
Power Consumption (Typical)
69 Watt
Power Consumption Stand by / Sleep
1 Watt
Dimensions & Weight Details
With stand - width: 64.2 cm - depth: 22.4 cm - height: 44.2 cm - weight: 6.6 kg , Without stand - width: 64.2 cm - depth: 4.2 cm - height: 39 cm
Shipping Width
72.5 cm
Shipping Depth
18.7 cm
Shipping Height
47.2 cm
Shipping Weight
9.6 kg
Sustainability Information
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
