With the Samsung S24B300HL LED Monitor, you'll have a monitor that offers both more energy efficiency and viewing comfort. Magic Angle technology means you can enjoy comfortable viewing from wider range of angles, allowing you to watch TV sitting, standing, or even lying down. Your Samsung LED monitor also features Eco Saving for reduced bills and environmental impact. It adjusts brightness according to your needs, with three different energy-saving modes.
See it your way with wider viewing angles.
How do you like to watch movies? Do you like lying down on the couch? Sitting in your favourite chair? Cooking or exercising? Whether you're standing, sitting or lying down, Samsung Magic Angle makes sure that the movie always takes centre stage and that you're always comfortable. This means, thanks to the 5-mode angle management, that whatever angle you watch your Samsung monitor, you will enjoy a full visual experience with amazing picture clarity. So, start seeing your favourite movies and other multimedia in total comfort and without limitations thanks to Magic Angle.
Control brightness, conserve energy.
Eco saving makes saving energy easy. It adjusts the brightness of your Samsung monitor based on how much energy you want to save. And with the choice of three energy saving modes (50%, 25% and Power Saving off), you can really tailor your monitor use to meet your own personal needs. Samsung's commitment to saving energy is designed to help both you and the environment, and with up to 50% saving on consumption, you can really make a positive impact on your eco footprint. Take the effort out of saving energy and take control with Eco saving
Enhanced viewing experience
With a 23.6-inch diagonal size and Full HD (1080p) video format, the Samsung S24B300HL offers a widescreen display that brings vivid, crisp visuals to any desktop setup. The LED backlight technology ensures a brighter image, enhancing the overall viewing experience. -
Versatile connectivity
Equipped with both HDMI and VGA interfaces, this monitor provides flexible connectivity options, allowing for easy setup with a wide range of devices. Whether connecting to a PC or Mac, the Samsung S24B300HL adapts to your workspace requirements. -
Optimized image quality
Featuring MagicBright 3, MagicColor, and Mega Dynamic Contrast Ratio, the monitor delivers optimized color and contrast. These technologies work together to produce sharper, more vibrant images. -
Ergonomic design
The tilt adjustment feature allows you to find the perfect viewing angle, reducing strain and enhancing comfort during long hours of use. Its sleek form factor makes it a stylish addition to any desktop.
- Samsung S24B300HL - SB300 Series - LED monitor - Full HD (1080p) - 23.6"
- LED-backlit LCD monitor - 23.6"
- Energy Class
- Class A
- Energy Consumption per Year
- 34 kWh
- Power Consumption (On mode)
- 23 W
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, VGA
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black, high gloss
- 56.9 cm x 19.7 cm x 41.6 cm
- 3.8 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified EPEAT Gold
- Display Type
- Energy Class
- Class A
- 34 kWh
- Diagonal Size
- 23.6"
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- LED backlight
- Power off timer, MagicTune, MagicColor, MagicAngle, MagicBright 3, Mega Dynamic Contrast Ratio
- Black, high gloss
- 56.9 cm x 19.7 cm x 41.6 cm - with stand
- 3.8 kg
- VGA , HDMI
Mechanical
- Tilt
- Cables Included
- 1 x VGA cable
- Power Supply
- External
- Input Voltage
- 23 W
- Power Consumption (Typical)
- 30 Watt
- Power Consumption Stand by / Sleep
- 0.3 Watt
- 0.3 Watt
- Dimensions & Weight Details
- With stand - width: 56.9 cm - depth: 19.7 cm - height: 41.6 cm - weight: 3.8 kg , Without stand - width: 56.9 cm - depth: 5.3 cm - height: 34.2 cm - weight: 3.5 kg
- Shipping Width
- 69.2 cm
- Shipping Depth
- 11.1 cm
- Shipping Height
- 41.5 cm
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
