Samsung's LED monitor delivers a visually stunning picture quality that leaves you speechless. Just as you've seen in Samsung LED TV's, the LED monitor makes colors more rich and the action more real than you've dreamt possible. Let the story come to life with vivid colors and crystal-clear detail.
With a response time of 5 ms, you can be sure that your monitor will perform perfectly, even in the fastest moving scenes. This stunning, seamless motion imaging presents movies, games, and Internet streamed content with precision and without the motion judder, blurring, and ghosting that can occur on a slower monitor, allowing you to enjoy a completely immersive viewing experience.
Breakthrough picture quality With LED technology
Samsung's LED monitor delivers a visually stunning picture quality that leaves you speechless. Just as you've seen in Samsung LED TV's, the LED monitor makes colors more rich and the action more real than you've dreamt possible. Let the story come to life with vivid colors and crystal-clear detail. -
Consume less energy and run cooler
Engineered with ecologically responsible consumers and businesses in mind, Samsung's LED technology reduces power consumption up to 40%-making the LED displays much more efficient than conventional LCD monitors. Your monitor will stay cool to the touch, even after a long day of hard work. Lower your monitor's power consumption without sacrificing performance with an LED backlight. -
Ultra slim design with high glossy finish
Remember when you replaced your bulky CRT monitor with a slimmer LCD monitor? The next leap forward is here. Samsung LED technology enables striking, ultra-thin displays. As slim as 11.4 mm, LED monitors add elegance to your desk. They are also very lightweight, making them easy to lift and move. -
Fast response time
- Samsung S24B150BL - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Panel Type
- TN
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.272 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- 5000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA
- Tilt
- Dark black
- 56.9 cm x 19.7 cm x 41.6 cm
- 3.6 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- DDC-2B, ISO 9241-307
- 2-year warranty
- Display Type
- Diagonal Size
- 24"
- Panel Type
- TN
- Native Resolution
- Pixel Pitch
- 0.272 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 56 - 61 Hz
- Horizontal Refresh Rate
- 30 - 75 kHz
- Video Bandwidth
- 89 MHz
- Horizontal Viewing Angle
- 90
- Vertical Viewing Angle
- 65
- Backlight Technology
- LED backlight
- Controls & Adjustments
- H/V position
- Power off timer, MagicTune, MagicColor, HDCP, MagicAngle, MagicBright 3, Mega Dynamic Contrast Ratio, Eco Saving
- Dark black
- 56.9 cm x 19.7 cm x 41.6 cm - with stand
- 3.6 kg
- VGA , DVI-D
Mechanical
- Tilt
- Tilt Angle
- -1/+20
- Included Accessories
- Stand
- Power Supply
- External
- Power Consumption (Typical)
- 30 Watt
- Power Consumption Stand by / Sleep
- 0.3 Watt
- Included Software
- Drivers & Utilities
- Dimensions & Weight Details
- With stand - width: 56.9 cm - depth: 19.7 cm - height: 41.6 cm - weight: 3.6 kg , Without stand - width: 56.9 cm - depth: 5.3 cm - height: 34.2 cm
- Shipping Weight
- 5.1 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 2 years
- 10 °C
- 40 °C
- 10 - 80% (non-condensing)
