Samsung SyncMaster S24B150BL 24" LED 1920x1080 DVI-D VGA - Black
Quicklinx: 892WWS00 Mfr#: LS24B150BL/EN
Samsung's LED monitor delivers a visually stunning picture quality that leaves you speechless. Just as you've seen in Samsung LED TV's, the LED monitor makes colors more rich and the action more real than you've dreamt possible. Let the story come to life with vivid colors and crystal-clear detail.
With a response time of 5 ms, you can be sure that your monitor will perform perfectly, even in the fastest moving scenes. This stunning, seamless motion imaging presents movies, games, and Internet streamed content with precision and without the motion judder, blurring, and ghosting that can occur on a slower monitor, allowing you to enjoy a completely immersive viewing experience.
  • Breakthrough picture quality With LED technology
  • Consume less energy and run cooler
    Engineered with ecologically responsible consumers and businesses in mind, Samsung's LED technology reduces power consumption up to 40%-making the LED displays much more efficient than conventional LCD monitors. Your monitor will stay cool to the touch, even after a long day of hard work. Lower your monitor's power consumption without sacrificing performance with an LED backlight.
  • Ultra slim design with high glossy finish
    Remember when you replaced your bulky CRT monitor with a slimmer LCD monitor? The next leap forward is here. Samsung LED technology enables striking, ultra-thin displays. As slim as 11.4 mm, LED monitors add elegance to your desk. They are also very lightweight, making them easy to lift and move.
  • Fast response time
Samsung S24B150BL - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Panel Type
TN
Native Resolution
Pixel Pitch
0.272 mm
Brightness
200 cd/m²
Contrast Ratio
5000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
Dark black
56.9 cm x 19.7 cm x 41.6 cm
3.6 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
DDC-2B, ISO 9241-307
Display Type
Diagonal Size
24"
Panel Type
TN
Native Resolution
Pixel Pitch
0.272 mm
Brightness
200 cd/m²
Contrast Ratio
5000000:1 (dynamic)
Colour Support
Response Time
5 ms
Vertical Refresh Rate
56 - 61 Hz
Horizontal Refresh Rate
30 - 75 kHz
Video Bandwidth
89 MHz
Horizontal Viewing Angle
90
Vertical Viewing Angle
65
Backlight Technology
LED backlight
Controls & Adjustments
H/V position
Power off timer, MagicTune, MagicColor, HDCP, MagicAngle, MagicBright 3, Mega Dynamic Contrast Ratio, Eco Saving
Dark black
56.9 cm x 19.7 cm x 41.6 cm - with stand
3.6 kg
VGA , DVI-D
Mechanical
Tilt
Tilt Angle
-1/+20
Stand
Power Supply
External
Power Consumption (Typical)
30 Watt
Power Consumption Stand by / Sleep
0.3 Watt
Included Software
Drivers & Utilities
Dimensions & Weight Details
With stand - width: 56.9 cm - depth: 19.7 cm - height: 41.6 cm - weight: 3.6 kg , Without stand - width: 56.9 cm - depth: 5.3 cm - height: 34.2 cm
Shipping Weight
5.1 kg
Sustainability Information
ENERGY STAR Certified
10 °C
10 - 80% (non-condensing)
