With a Samsung SA450 business monitor, you'll discover more comfortable viewing and greater energy-efficiency. Optimise your viewpoint by making adjustments to height, perspective and tilt that can benefit your posture as well as productivity. Moving and setting up your SA450 is easier too, with its lightweight and innovative design. Features like cable arrangement and the detachable adaptor also help you minimise clutter and maximise space. It's more energy efficient when in use and even allows you to reduce power consumption when it's not, thanks to the Adaptor On Off switch.
Conveniently adjust monitor height, tilt and perspective
The Samsung LED Business Monitor SA450 has been designed to help boost work efficiency, delivering a tailored experience with its choice of viewer settings. The height-adjustable stand ensures that the screen can always be set at the optimal eye level, which enhances the visual experience while also helping maintain the viewer's body posture. Other features include the tilt and pivot capabilities, which not only increase comfort levels but also introduce new ways of working. The SA450 Monitor can rotate 90° degrees, allowing for more appropriate view depending on the work. So, now you can take convenience and efficiency to amazing heights with the Samsung LED Business Monitor SA450. -
Maximise workspace with an efficient detachable adaptor
If you need a work monitor that uses office space efficiently, then Samsung LED Business Monitor SA450 is the perfect choice. It features an innovative new detachable adaptor, which allows the monitor to be easily moved and installed. From physically moving the monitor with the carrying handle to quickly installing, the SA450 is ready to deliver an efficient and clean work space. The SA450 is also equipped and prepared for you as a VESA Wall mount, providing a multi-screen or wall mounted monitor. Optimising your office space is now easily achieved with the Samsung LED Business Monitor SA450. -
Enjoy energy savings with the lightweight LED display
Samsung's lightweight LED Business Monitor SA450 provides another energy saving option through its low consumption levels. This reduction in energy helps both financial and environmental aspects of the business, and is an important part of any work operation. The LED Business Monitor SA450 is also remarkably lightweight and reduces the hassles associated with transporting monitors, and is just one more way that Samsung is helping enhance the working environment. -
Go green with Samsung's Adaptor On Off 0W
The ultimate energy saving measure has been created by Samsung with the new Adaptor On Of mode. By simply flicking the mechanical switch found on the Samsung LED Business monitor SA450, you can cut energy output while not using the monitor down to an amazing 0 Watts. Conventional standby modes reduce energy output to about 1 Watt, but the SA450 goes one stop further for greater results. This helps minimises both environmental impact and operating costs, and is just one more step by Samsung in creating a greener environment. -
Clear your desk with Samsung's Cable Arrangement
A tidy and clean workspace is paramount when it comes to showing professionalism at work. That's why the Samsung LED Business Monitor SA450 comes with a Cable Arrangement. It conveniently organises the cables coming from the monitor into a simple bundle along the stand and helps minimise clutter around the screen. With the Samsung LED Business Monitor SA450, you can finally enjoy a neat workspace, where annoying cables are kept out of sight.
- Samsung S24A450BW - LED monitor - 24"
- LED-backlit LCD monitor - 24"
- Native Resolution
- 1920 x 1200
- Pixel Pitch
- 0.27 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA
- Height, pivot (rotation), tilt
- Matte black
- 56 cm x 20.1 cm x 40 cm
- 6.7 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- TUV GS, DDC-2B, ISO 9241-307
- 3-year warranty
- Display Type
- Diagonal Size
- 24"
- Native Resolution
- 1920 x 1200
- Pixel Pitch
- 0.27 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 61 Hz
- Horizontal Refresh Rate
- 75 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- LED backlight
- Power off timer, MagicColor, HDCP, MagicAngle, MagicBright 3
- Matte black
- 56 cm x 20.1 cm x 40 cm - with stand
- 6.7 kg
- VGA , DVI-D
Mechanical
- Tilt Angle
- 25
- Height Adjustment
- 100 mm
- Wall mountable
- Power Supply
- External
- Power Consumption (Typical)
- 29 Watt
- Power Consumption Stand by / Sleep
- 0.3 Watt
- Dimensions & Weight Details
- With stand - width: 56 cm - depth: 20.1 cm - height: 40 cm - weight: 6.7 kg , Without stand - width: 56 cm - depth: 5 cm - height: 37.4 cm - weight: 5.1 kg
- Shipping Width
- 63.8 cm
- Shipping Depth
- 20 cm
- Shipping Height
- 45.3 cm
- Shipping Weight
- 6.7 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years - pick-up and return
