Samsung SyncMaster S24A300BL 23.6" LED Backlit LCD Display - 5ms, DVI, VGA
Quicklinx: 7TW1WS00 Mfr#: LS24A300BL/EN
The Samsung S24A300B LED Monitor incorporates a host of amazing features to boost both your work and entertainment needs.
The monitor's amazing performance is matched by innovative eco solutions like the unique Eco savings function, which ensures that the outstanding experience also minimises its impact on the environment.
Features such as the Mega Dynamic Contrast and Wide angle viewing deliver a visual experience that will lift your multimedia content to new heights. With so many brilliant features, the S24A300B Monitor is ready to change the way you interact with your monitor.
Diagonal Size
23.6 in
Max Resolution
1920 x 1080
Response Time
5 ms
Speakers
None
VGA (HD-15)
Glossy black
Dimensions & Weight / Depth
5.3 cm
Dimensions & Weight / Height
34.2 cm
Dimensions & Weight / Width
56.9 cm
Display (Projector) / Image Brightness
250 cd/m2
Display (Projector) / Image Contrast Ratio
1000:1
Header / Product Line
Samsung SyncMaster
TFT active matrix
