The Samsung S24A300B LED Monitor incorporates a host of amazing features to boost both your work and entertainment needs.
The monitor's amazing performance is matched by innovative eco solutions like the unique Eco savings function, which ensures that the outstanding experience also minimises its impact on the environment.
Features such as the Mega Dynamic Contrast and Wide angle viewing deliver a visual experience that will lift your multimedia content to new heights. With so many brilliant features, the S24A300B Monitor is ready to change the way you interact with your monitor.
- Diagonal Size
- 23.6 in
- Max Resolution
- 1920 x 1080
- Response Time
- 5 ms
- Speakers
- None
- VGA (HD-15)
- Glossy black
- Dimensions & Weight / Depth
- 5.3 cm
- Dimensions & Weight / Height
- 34.2 cm
- Dimensions & Weight / Width
- 56.9 cm
- Display (Projector) / Image Brightness
- 250 cd/m2
- Display (Projector) / Image Contrast Ratio
- 1000:1
- Header / Product Line
- Samsung SyncMaster
- Technology
- TFT active matrix
