Samsung SyncMaster NC240 PCoIP - All-in-one - 1 x Tera1100- RAM 128 MB-24" Widescreen TFT
Quicklinx: 7NB8WS00 Mfr#: LF24PPBCB/EN
Adding a secure workstation is as simple as adding the Samsung NC240 23.6" LCD monitor. This integrated All-in-one monitor feature PC-over-IP technology, as an alternative to the traditional desktop PC, and means you sacrifice nothing and gain efficiencies when working directly from the central server. The NC240 is the secure way to better manage your business.
  • Full USB device support
    With 4 USB ports and full USB device support, users can access a wide range of USB peripheral devices directly through the monitor, enhancing connectivity whilst maintaining the security of the system.
  • Real-time graphics
    Through hardware decoding a wide variety of content can be supported from video using any CODEC all the way to high performance 3D content when using a PCoIP enabled workstation platform.
  • Security you can trust
    Because software is installed, and important information is stored on centralized host platforms, the entire system is secured against viruses, information leaks, and internal and external attack.
  • Low cost, low maintenance
    Because all software and data is stored on the centralized host platform, time and money spent on managing the system is vastly reduced, enabling the creation of a network that is easy to install and easy to maintain.
  • Access to superior graphics
    Superior graphics are enabled by the PCoIP protocol, giving users access to full performance graphics from VMware View enabled virtual machines. Full 3D performance is also available when using PCoIP enabled workstation platforms or PCoIP Host cards in standard PC's in conjunction with a GPU.
Samsung NC240 PCoIP - all-in-one Tera1100 - 128 MB - LCD 24"
Thin client - all-in-one - wall mountable, swivel adjustment, PC over IP (PCoIP) technology, adjustable height
1 x Teradici Tera1100
RAM
128 MB XDRAM
Optical Storage
No optical drive
Monitor
24" - LCD - 1920 x 1080 (Full HD) - 16:9
Audio Output
Integrated
1GbE
Software Included
Drivers & Utilities, Microsoft RDP
56.9 cm x 22.6 cm x 38.5 cm
10 kg
Environmental Standards
ENERGY STAR Qualified
Thin client
Product Form Factor
All-in-one
Processor / Chipset
CPU
Teradici Tera1100
CPU Qty
1
Max CPU Qty
1
RAM
Installed Size
128 MB
XDRAM
Optical Storage
No optical drive
Monitor
Monitor Type
LCD
Diagonal Size
24"
Native Resolution
Widescreen Display
Image Aspect Ratio
16:9
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Pixel Pitch
0.272 cm
Response Time
5 ms
Image Brightness
300 cd/m²
Image Contrast Ratio
1000:1
Graphics Controller
Integrated
Video Interfaces
VGA, DVI
Audio Output
Integrated
Integrated
Slots
Memory , 1 (total) / 0 (free) x CPU
4 x USB , 1 x DVI-D output , 1 x VGA input , 1 x VGA output , 1 x headphones , 1 x audio line-in , 1 x LAN (Gigabit Ethernet) , 1 x microphone
Wall mountable, swivel adjustment, PC over IP (PCoIP) technology, adjustable height
Theft/Intrusion Protection
VESA Mounting Interface
100 x 100 mm, 100 x 200 mm
DDC-2B, ISO 13406-2
Power supply
67 Watt
Power Consumption Stand by / Sleep
2 Watt
Operating System / Software
Software
Sustainability Information
ENERGY STAR Certified
56.9 cm
22.6 cm
38.5 cm
10 kg
Shipping Width
65 cm
Shipping Depth
19.2 cm
Shipping Height
41.8 cm
10 °C
10 - 80%
