Samsung SyncMaster F2380 23" Widescreen 1920 x 1080 8ms 2 x DVI VGA LCD Monitor
Quicklinx: 631ZWS00 Mfr#: LS23NVTABW/EN
The Samsung F2380 will exceed even the highest of expectations. With 100% support of sRGB colour mode and its wide viewing angle of 178-¦, the display will be smooth and enjoyable to everyone gathered around your screen. Its modern design delivers a virtually seamless display area when tiling multiple displays, and will turn multi tasking into a visual pleasure.
  • HDCP (High-Bandwidth Digital Content Protection)
    HDCP, or High-bandwidth Digital Content Protection, is Samsung's innovative way of protecting the integrity of the content that's being transmitted to your monitor through the DVI interface. This naturally delivers the highest resolution images, allowing you to enjoy 100% pure digital content, all the time.
  • Mega colour, Mega contrast, Mega experience
    There's dynamic and then there's Mega Dynamic. With an upgraded contrast ratio of 3000:1 (150000:1 DCR), Samsung monitors deliver professional picture quality that makes colours more rich and real then you've dreamt possible. So real, you'll see each eye-popping colour and crystal-clear detail come to life right on your screen.
  • Take a Wider View
    With Samsung Monitors' ultra-high contrast PVA panel, you get rich, vivid colours and incredible image clarity from virtually any place you stand, or sit. Our innovative wide viewing angle technology ensures pristine picture quality and complete sRGB colour space coverage whether you choose to interact with your PC head-on, or take in a movie while multitasking somewhere else in the room.
  • Super-slim, superior style
    Super-slim, designed to optimise user-performance. The 15mm bezel maximises screen space, 2.5mm crater depth minimise light reflection, and 130mm adjustable stand enables precise screen placement.
  • 10% PCM based material included
    The Samsung monitors are positioned at the cutting-edge of green electronics, making ecological design, manufacture, and operation a top priority. EPEAT Gold label was acquired in US. What's EPEAT Gold?EPEAT is a rating system that allows purchasers to evaluate IT products based on all aspects of their environmental performance, from manufacturing to recycling. Three tiers of rating are available: Bronze, Silver, and Gold.
Samsung SyncMaster F2380 - LCD monitor - Full HD (1080p) - 23"
LCD monitor - 23"
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.265 mm
Brightness
300 cd/m²
Contrast Ratio
150000:1 (dynamic)
Response Time
8 ms
Colour Support
16.7 million colours
Input Connectors
2xDVI-D, VGA
54.5 cm x 21.6 cm x 47.7 cm
6.3 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
TUV GS, DDC-2B, ISO 13406-2, RoHS
3-year warranty
Display Type
LCD monitor / TFT active matrix
Diagonal Size
23"
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.265 mm
Brightness
300 cd/m²
Contrast Ratio
150000:1 (dynamic)
Colour Support
Response Time
8 ms
Vertical Refresh Rate
75 Hz
Horizontal Refresh Rate
75 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
MagicTune, MagicWizard, MagicSpeed, MagicColor, HDCP, HD Ready, MagicBright 3
6.3 kg
VGA , 2 x DVI-D
Power Supply
External
Power Consumption (Typical)
45 Watt
Power Consumption Stand by / Sleep
1 Watt
Shipping Width
62.8 cm
Shipping Depth
17.7 cm
Shipping Height
41.3 cm
Shipping Weight
7.9 kg
Sustainability Information
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Limited warranty - 3 years - on-site
Resources
The following resources are available for the Samsung SyncMaster F2380 23" Widescreen 1920 x 1080 8ms 2 x DVI VGA LCD Monitor
