The Samsung F2380 will exceed even the highest of expectations. With 100% support of sRGB colour mode and its wide viewing angle of 178-¦, the display will be smooth and enjoyable to everyone gathered around your screen. Its modern design delivers a virtually seamless display area when tiling multiple displays, and will turn multi tasking into a visual pleasure.
HDCP (High-Bandwidth Digital Content Protection)
HDCP, or High-bandwidth Digital Content Protection, is Samsung's innovative way of protecting the integrity of the content that's being transmitted to your monitor through the DVI interface. This naturally delivers the highest resolution images, allowing you to enjoy 100% pure digital content, all the time. -
Mega colour, Mega contrast, Mega experience
There's dynamic and then there's Mega Dynamic. With an upgraded contrast ratio of 3000:1 (150000:1 DCR), Samsung monitors deliver professional picture quality that makes colours more rich and real then you've dreamt possible. So real, you'll see each eye-popping colour and crystal-clear detail come to life right on your screen. -
Take a Wider View
With Samsung Monitors' ultra-high contrast PVA panel, you get rich, vivid colours and incredible image clarity from virtually any place you stand, or sit. Our innovative wide viewing angle technology ensures pristine picture quality and complete sRGB colour space coverage whether you choose to interact with your PC head-on, or take in a movie while multitasking somewhere else in the room. -
Super-slim, superior style
Super-slim, designed to optimise user-performance. The 15mm bezel maximises screen space, 2.5mm crater depth minimise light reflection, and 130mm adjustable stand enables precise screen placement. -
10% PCM based material included
The Samsung monitors are positioned at the cutting-edge of green electronics, making ecological design, manufacture, and operation a top priority. EPEAT Gold label was acquired in US. What's EPEAT Gold?EPEAT is a rating system that allows purchasers to evaluate IT products based on all aspects of their environmental performance, from manufacturing to recycling. Three tiers of rating are available: Bronze, Silver, and Gold.
- Samsung SyncMaster F2380 - LCD monitor - Full HD (1080p) - 23"
- LCD monitor - 23"
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.265 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 150000:1 (dynamic)
- Response Time
- 8 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- 2xDVI-D, VGA
- Black
- 54.5 cm x 21.6 cm x 47.7 cm
- 6.3 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified EPEAT Gold
- TUV GS, DDC-2B, ISO 13406-2, RoHS
- 3-year warranty
- Display Type
- LCD monitor / TFT active matrix
- Diagonal Size
- 23"
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.265 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 8 ms
- Vertical Refresh Rate
- 75 Hz
- Horizontal Refresh Rate
- 75 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- MagicTune, MagicWizard, MagicSpeed, MagicColor, HDCP, HD Ready, MagicBright 3
- Black
- 6.3 kg
- VGA , 2 x DVI-D
- Power Supply
- External
- Power Consumption (Typical)
- 45 Watt
- Power Consumption Stand by / Sleep
- 1 Watt
- Shipping Width
- 62.8 cm
- Shipping Depth
- 17.7 cm
- Shipping Height
- 41.3 cm
- Shipping Weight
- 7.9 kg
Sustainability Information
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- Limited warranty - 3 years - on-site
