Perfect high speed performance With a response time of 5ms, you can be sure that your monitor will perform perfectly, even in the fastest moving scenes. This stunning, seamless motion imaging presents movies, games, and internet streamed content with precision and without the motion judder, blurring, and ghosting that can occur on a slower monitor, allowing you to enjoy a completely immersive viewing experience.
Mega colour, Mega contrast, Mega experience There's dynamic and then there's Mega Dynamic. With an upgraded contrast ratio - the highest level of contrast ratio currently available - Samsung monitors deliver professional picture quality that makes colours more rich and real then you've dreamt possible. So real, you'll see each eye-popping colour and crystal-clear detail come to life right on your screen.
Control brightness, conserve energy. Magic Eco makes saving energy easy. It adjusts Samsung monitor's brightness based on how much energy you want to save. You have four energy saving options to choose from: 100%, 75%, and 50% power consumption as well as ‘power saving off'. If Magic Eco is turned off, you still enjoy the option of using Samsung's Magic Bright feature, engineered to let you manually adjust the screen's brightness. Take the effort out of saving energy and take control with Magic Eco.
Save space. And the environment. Samsung's ultra-slim LED monitors will revolutionize your personal computing environment while positively impacting the Earth's environment. Halogen- and lead-free, recyclable and engineered to consume less power, Samsung monitors are decidedly more eco-friendly than conventional CCFL monitors. The innovative LED engineering also means they take up a lot less space and offer super-fast response times, ensuring that you get a more efficient and more enjoyable computing experience.
Conserves energy, preserves the environment.
Engineered with the ecologically responsible homeowner in mind, the Samsung monitor reduces power consumption by 40%, making it much more efficient than conventional monitors. By reducing the number of LED and defaulting to standby power, which requires less than 0.3W as opposed to the typical 1.0W, the Samsung monitor is poised to make a difference. How big a difference? If your monitor saves 120W each day, that's the annual equivalent of eliminating 10.8kg of CO2 emitted from an oil-burning power plant-which produces the same effect as planting four pine trees.
Key Selling Points
Save space. And the environment Conserves energy, preserves the environment
