Samsung SyncMaster BX2240W 22" Widescreen 1680 x 1050 5MS VGA DVI-D LED Monitor
Quicklinx: 73ZQWS00 Mfr#: LS22CBWMBVUEN
As one of the few panel manufacturers we are all too aware of the potential benefits, savings and variance in the quality of different manufacturers LED BLU displays. Invest wisely, reduce your running costs and improve results with Samsung.
  • Perfect high speed performance
    With a response time of 5ms, you can be sure that your monitor will perform perfectly, even in the fastest moving scenes. This stunning, seamless motion imaging presents movies, games, and internet streamed content with precision and without the motion judder, blurring, and ghosting that can occur on a slower monitor, allowing you to enjoy a completely immersive viewing experience.
  • Mega colour, Mega contrast, Mega experience
    There's dynamic and then there's Mega Dynamic. With an upgraded contrast ratio – the highest level of contrast ratio currently available – Samsung monitors deliver professional picture quality that makes colours more rich and real then you've dreamt possible. So real, you'll see each eye-popping colour and crystal-clear detail come to life right on your screen.
  • Feel the Effects of Colour
    Enhance images your way using Samsung's advanced ColourEffect feature. Open your eyes to a completely Customised viewing experience as you play with photographic effects that match your mood. Choose from Aqua, Sepia, Green and Grayscale to interact with your display in a whole new way – namely, yours.
  • Save space. And the environment
    Samsung's ultra-slim LED monitors will revolutionize your personal computing environment while positively impacting the Earth's environment. Halogen- and lead-free, recyclable and engineered to consume less power, Samsung monitors are decidedly more eco-friendly than conventional CCFL monitors. The innovative LED engineering also means they take up a lot less space and offer super-fast response times, ensuring that you get a more efficient and more enjoyable computing experience.
  • Conserves energy, preserves the environment
    Engineered with the ecologically responsible homeowner in mind, the Samsung monitor reduces power consumption by 40%, making it much more efficient than conventional monitors. By reducing the number of LED and defaulting to standby power, which requires less than 0.3W as opposed to the typical 1.0W, the Samsung monitor is poised to make a difference. How big a difference? If your monitor saves 120W each day, that's the annual equivalent of eliminating 10.8kg of CO2 emitted from an oil-burning power plant—which produces the same effect as planting four pine trees.
Samsung SyncMaster BX2240W LED - LED monitor - 22"
LED-backlit LCD monitor - 22"
Panel Type
TN
Aspect Ratio
16:10
Native Resolution
1680 x 1050
Pixel Pitch
0.282 mm
Brightness
250 cd/m²
Contrast Ratio
5000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-I, VGA
Display Position Adjustments
51.1 cm x 22 cm x 39.3 cm
5.2 kg
Environmental Standards
ENERGY STAR Qualified
TUV GS, DDC-2B, ISO 13406-2
3-year warranty
Display Type
Diagonal Size
22"
Panel Type
TN
Aspect Ratio
16:10
Native Resolution
1680 x 1050
Pixel Pitch
0.282 mm
Brightness
250 cd/m²
Contrast Ratio
5000000:1 (dynamic)
Colour Support
Response Time
5 ms
Vertical Refresh Rate
75 Hz
Horizontal Refresh Rate
81 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Power off timer, MagicTune, MagicWizard, HDCP, MagicAngle, MagicReturn, MagicEco, MagicBright 3
5.2 kg
VGA , DVI-D
Mechanical
VESA Mounting Interface
75 x 75 mm
Wall mountable
Power Supply
Internal
Power Consumption (Typical)
24 Watt
Power Consumption Stand by / Sleep
0.3 Watt
Shipping Width
58.7 cm
Shipping Depth
41.6 cm
Shipping Height
19.3 cm
Shipping Weight
7.2 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years - pick-up and return
