Samsung SyncMaster B2030 20" Widescreen 1600 x 900 5MS DVI-D VGA LCD Monitor
Quicklinx: 6LSQWS00 Mfr#: LS20PUZKF/EN
Complement your busy lifestyle with a monitor that knows exactly what you require; you want all the cool functions in an ultra - slim stylish screen. Featuring Dynamic Control for brilliant colours and fast screen response times for smooth, blur - free visuals, this monitor delivers a quality performance every time while still providing an eco - friendly option.
  • Perfect high speed performance
    With a response time of 5ms, you can be sure that your monitor will perform perfectly, even in the fastest moving scenes. This stunning, seamless motion imaging presents movies, games, and internet streamed content with precision and without the motion judder, blurring, and ghosting that can occur on a slower monitor, allowing you to enjoy a completely immersive viewing experience.
  • Get into the details
    The differences make all the difference. That's why the Samsung ultra-high 50000:1 Dynamic Contrast ratio automatic backlight adjustment creates deeper, more dramatic dark tones and brighter, more striking light tones. Now you can enjoy images that echo reality with rich, vivid color and brilliant natural intensity. When it comes down to the details, conventional monitors simply pale in comparison.
  • Reduce eyestrain. Enhance your viewing experience
    How do you like to watch movies? Do you like lying down on the couch? Sitting in your favourite chair? Cooking or exercising? Whether you're standing, sitting or lying down, Samsung's Magic Angle makes sure that the movie always takes centre stage. And that you're always comfortable. Wherever you place the Samsung monitor, its 5-mode angle management allows you to extend its viewing angle so the screen always appears as if viewed face-on. So stop craning your neck and start enjoying the movie.
  • Control brightness, conserve energy
    Magic Eco makes saving energy easy. It adjusts Samsung monitor's brightness based on how much energy you want to save. You have four energy saving options to choose from: 100%, 75%, and 50% power consumption as well as ‘power saving off'. If Magic Eco is turned off, you still enjoy the option of using Samsung's Magic Bright feature, engineered to let you manually adjust the screen's brightness. Take the effort out of saving energy and take control with Magic Eco.
  • A monitor that takes the initiative to share
    With Samsung's Magic Return you never have to worry about your second monitor losing content. If the cable disconnects and the signal disappears, Magic Return automatically transfers the content from that screen to the other monitor before turning off. There's no magic here. We just have content sharing down to a science.
Diagonal Size
20 in
Max Resolution
1600 x 900
Response Time
5 ms
Speakers
None
DVI, D-sub
Black gloss
4.1 kg
Display (Projector) / Image Brightness
250 cd/m2
Display (Projector) / Image Contrast Ratio
1000:1
