Samsung SyncMaster B1940R 19" 1280 x 1024 5MS DVI-I VGA LCD Monitor
Quicklinx: 7098WS00 Mfr#: LS19CBBMB/EN
The Samsung B1940R is all about delivering high performance business that suit both your vision and your budget. The LCD monitor produces mesmerising visuals while features, such as Windows 7, MagicReturn, energy saving modes and other innovative custom key applications, will have you working with higher levels of productivity and comfort.
  • Perfect high speed performance
    With a response time of 5ms, you can be sure that your monitor will perform perfectly, even in the fastest moving scenes. This stunning, seamless motion imaging presents movies, games, and internet streamed content with precision and without the motion judder, blurring, and ghosting that can occur on a slower monitor, allowing you to enjoy a completely immersive viewing experience.
  • Get into the details
    The differences make all the difference. That's why the Samsung ultra-high 50000:1 Dynamic Contrast ratio automatic backlight adjustment creates deeper, more dramatic dark tones and brighter, more striking light tones. Now you can enjoy images that echo reality with rich, vivid colour and brilliant natural intensity. When it comes down to the details, conventional monitors simply pale in comparison.
  • Reduce eyestrain. Enhance your viewing experience
    How do you like to watch movies? Do you like lying down on the couch? Sitting in your favourite chair? Cooking or exercising? Whether you're standing, sitting or lying down, Samsung's Magic Angle makes sure that the movie always takes centre stage. And that you're always comfortable. Wherever you place the Samsung monitor, its 5-mode angle management allows you to extend its viewing angle so the screen always appears as if viewed face-on. So stop craning your neck and start enjoying the movie.
  • Control brightness, conserve energy
    Magic Eco makes saving energy easy. It adjusts Samsung monitor's brightness based on how much energy you want to save. You have four energy saving options to choose from: 100%, 75%, and 50% power consumption as well as ‘power saving off'. If Magic Eco is turned off, you still enjoy the option of using Samsung's Magic Bright feature, engineered to let you manually adjust the screen's brightness. Take the effort out of saving energy and take control with Magic Eco.
  • A monitor that takes the initiative to share
    With Samsung's Magic Return you never have to worry about your second monitor losing content. If the cable disconnects and the signal disappears, Magic Return automatically transfers the content from that screen to the other monitor before turning off. There's no magic here. We just have content sharing down to a science.
Samsung SyncMaster B1940R - LCD monitor - 19"
LCD monitor - 19"
Native Resolution
1280 x 1024 at 75 Hz
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 50000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-I, VGA, composite video
Display Position Adjustments
Height, tilt
41.7 cm x 22 cm x 39 cm
4.8 kg
Microsoft Certification
Certified for Windows Vista
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
DDC-2B
Display Type
LCD monitor / TFT active matrix
Diagonal Size
19"
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
75 Hz
Horizontal Refresh Rate
81 kHz
Video Bandwidth
135 MHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Controls & Adjustments
Colour temperature
Sync on Green, power off timer, MagicColor, HDCP, MagicAngle, MagicEco, MagicBright 3
4.8 kg
VGA , DVI-D
Mechanical
Height, tilt
Height Adjustment
130 mm
VESA Mounting Interface
75 x 75 mm
Wall mountable
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
DDC-2B
Power Supply
Internal
Power Consumption (Typical)
22 Watt
Power Consumption Stand by / Sleep
0.3 Watt
Shipping Width
52.8 cm
Shipping Depth
19.3 cm
Shipping Height
42.4 cm
Shipping Weight
6.2 kg
Sustainability Information
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
10 °C
10 - 80%
