Take the hassles out of your communications with a powerful and flexible screen like the 400BX LFD. Featuring an innovative design that allows for quick and easy video walls and built-in speakers for a full multimedia experience, it is the resource you business needs to stand out. Its brilliant picture quality is supported by internal cooling system that ensures you messaging can stand the test of time. So, give your business the right tools and discover the easy way of reaching your audience.
Choose The Right View, Landscape Or Portrait
This Samsung LFD gives you the flexibility to display your image vertically or horizontally-whatever the situation calls for. With a pivot function that rotates the screen 90° degrees and the freedom to display presentations in portrait mode or advertisements in landscape mode, this makes for one versatile monitor. -
Save money, save space with built-in speakers
Maximize your impact with a great picture and crisp audio. Your message will be heard loud and clear with built-in speakers. You'll save money when you eliminate the cost of purchasing separate speakers, and you'll save valuable space as well. -
A cool way to ensure longevity
Enjoy continuous, reliable operation thanks to a built-in fan control. Housed inside of the LFD, the fan guarantees you can count on it for years to come without worrying about it overheating. You can even control the fan with an easy-to-use on screen display. -
A video wall that lives up to your standards
Create the ultimate video wall with Samsung LFDs that cater to your needs. And because this LFD has an embedded video matrix processor, it supports 1 x 1 to 10 x 10 wall formats, allowing you to enjoy total convenience. Best yet, since they need no additional support, the possibilities are almost endless. -
A great picture that's glare-free
Whether you have a story to tell or a product to sell, it's important that your image is crystal clear. This Samsung LFD delivers just that-even if your display is located in a brightly-lit environment. It eliminates any reflections that can disrupt your ad's readability, keeping images smooth and visible.
- Samsung 400BX 40" LCD flat panel display - Full HD
- Product Type
- LCD flat panel display
- Diagonal Class
- 40"
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Video Interface
- Composite
- PC Interface
- DVI, VGA (HD-15)
- Technology
- S-PVA
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Sound Output Mode
- Stereo
- Speaker System
- 2 speakers
- Included Accessories
- Remote control
- Microsoft Certification
- Compatible with Windows 7
- Voltage
- AC 120/230 V (50/60 Hz)
- 220 Watt
- 96.9 cm x 9.1 cm x 58.2 cm
- 13.8 kg
- Environmental Standards
- ENERGY STAR Qualified
- Product Type
- 220 Watt
- Diagonal Class
- 40"
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Temperature sensor
- Video Interface
- Composite
- PC Interface
- DVI, VGA (HD-15)
- 96.9 cm
- 9.1 cm
- 58.2 cm
- 13.8 kg
Display
- LCD Display Technology
- S-PVA
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- Colour Depth
- 16.7 million colours
- Image Contrast Ratio
- 3000:1
- Dynamic Contrast Ratio
- 10000:1
- Brightness
- 450 cd/m²
- Colour Gamut
- 72%
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Pixel Pitch
- 0.461 mm
- Response Time
- 8 ms
- Max V-Sync Rate
- 85 Hz
- Max H-Sync Rate
- 81 kHz
- Pivot, Anti Retention
Stands & Mounts
- Flat Panel Mount Interface
- 400 x 400 mm
Remote Control
- Remote control
Audio System
- Sound Output Mode
- Stereo
- Surround Mode
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Speakers
- 2 x main channel speaker - 10 Watt
- Connector Type
- DVI-D input , VGA / component video input , Serial , Composite video input , Audio line-in
- Cables Included
- VGA cable
- MPR II, TUV, C-Tick, BSMI, GOST, cUL, DDC-2B, EN55022, NEMKO, NOM, SIQ, EN55024, CISPR 22, CCC, EN 60065, IEC 60065, FCC Part 15, PSB, EK, AS/NZS 3548, DDC/CI, IRAM, KCC, VCCI V-3
- ENERGY STAR Certified
- ENERGY STAR Version
- 5.0
- Power Device
- Power supply - internal
- Input Voltage
- Power Consumption Stand by / Sleep
- 1 Watt
- Width (Shipping)
- 105 cm
- Depth (Shipping)
- 20.3 cm
- Height (Shipping)
- 66.7 cm
- Weight (Shipping)
- 15 kg
- 0 °C
- 40 °C
- 10 - 80%
