- Samsung SyncMaster 206BW - LCD monitor - 20"
- LCD monitor - 20"
- Panel Type
- TN
- Aspect Ratio
- 16:10
- Native Resolution
- 1680 x 1050
- Brightness
- 300 cd/m²
- Contrast Ratio
- 800:1 / 3000:1 (dynamic)
- Response Time
- 2 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA
- Swivel, tilt
- High-gloss black
- 47.6 cm x 21.9 cm x 39.6 cm
- 5.3 kg
- Microsoft Certification
- Certified for Windows Vista
- Environmental Standards
- ENERGY STAR Qualified EPEAT Silver
- DDC-2B, ISO 13406-2, NUTEK
- Display Type
- LCD monitor / TFT active matrix
- Diagonal Size
- 20"
- Panel Type
- TN
- Aspect Ratio
- 16:10
- Native Resolution
- 1680 x 1050
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 2 ms
- Vertical Refresh Rate
- 75 Hz
- Horizontal Refresh Rate
- 81 kHz
- Horizontal Viewing Angle
- 160
- Vertical Viewing Angle
- 160
- Controls & Adjustments
- Brightness, contrast, H/V position, sharpness, colour balance, gamma correction, colour temperature
- OSD-Digital Display Director, MagicBright 2, Sync on Green, MagicTune, HDCP, MagicBright 3
- High-gloss black
- 5.3 kg
- 1 x VGA - 15 pin HD D-Sub (HD-15) , 1 x DVI-D - 24+1 pin digital DVI
Mechanical
- Swivel, tilt
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), wall mountable
- Cables Included
- 1 x VGA cable
- Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
- Power Supply
- Internal
- Power Consumption (Typical)
- 55 Watt
- Power Consumption Stand by / Sleep
- 1 Watt
- Included Software
- Drivers & Utilities, Natural Color Pro
Sustainability Information
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
- 10 °C
- 40 °C
- 10 - 80%
Customer reviews
Write a review for the Samsung SyncMaster 206BW - TFT - 20" here!
Reviewed by CP. Review Posted 28/06/2007
Faultless monitor and superb value for money. Do your eyes a favour - go buy one. Took 5 minutes to unpack, assemble and have working. Replaces a 19" Viewsonic (superb picture quality, but not widescreen) and so I did not expect the picture quality itself to be any better - I was stunned at the improvement. STALKER, Oblivion, COH and DVD's all look outstanding. I cannot fault the monitor in any way; looks fantastic, easy adjustment and no dead pixels. Outstanding value for money as well (cost me 2/3 the price of the 22" version which has the same resolution) The service from Dabs was, as ever, excellent - (thank you.) ASUS P5K, Core 2 duo 6420 @2.8Ghz 4 x Gig 6400 4-4-4-12 RAM POV Geforce 8800 GTS
                        Overall
                        Ease of use
                        Value for money
Wide Screen Heaven
Reviewed by Jim. Review Posted 27/09/2007
I pondered for some time about moving to wide screen as I don't watch films on my PC. I'm on to my 4th TFT and this beats the lot. Easy to setup, looks the biz and a picture quality second to none. DVI and RGB cables included which is nice. What swings it for me is the fact I can now work on two pages at a time in word without having to scroll up or down. I would have liked to be able to heighten the monitor an inch or so but the stand doesn't adjust up so that's not possible. Not a big problem but maybe something for Samsung to consider? Next day delivery means "next day" at Dabs, and the whole shopping experience has been top notch. Well pleased!
                        Overall
                        Ease of use
                        Value for money
Reviewed by rubaduk. Review Posted 01/11/2007
I'm a happy bunny.I can only echo what everyone else has said, this monitor is pure dead brilliant. Buy it, you wont be dissappointed, and buy it from Dabs, I ordered it one day and it was delivered next day at 10.30am and I live up in Scotland. Excuse me, I have to get back to BioShock.
                        Overall
                        Ease of use
                        Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
