Samsung SSD INT 990 EVO PLUS 1TB PCIE M.2
Quicklinx: HXZ4WS00 Mfr#: MZ-V9S1T0BW
Form Factor: M.2 2280
Type: Solid state drive
Capacity: 1TB, 1TB
£176.78 ex VAT
£212.13 inc VAT
The Samsung 990 EVO Plus is an internal solid state drive designed for demanding applications. With a robust capacity of 1 TB, it ensures ample storage for a variety of files and applications. The drive utilizes PCI Express 5.0 and boasts internal data rates of up to 7150 MBps, allowing for quick data retrieval and minimal load times. Samsung’s V-NAND TLC Technology enhances performance and endurance, making it suitable for both everyday computing and intensive tasks. This drive is engineered to withstand a range of environmental conditions, operating effectively in temperatures from 0°C to 70°C and withstanding storage temperatures as low as -40°C and as high as 85°C. It features TRIM support and an Auto Garbage Collection Algorithm, ensuring optimal performance over time. Security is prioritized with hardware encryption and compliance with TCG Opal Encryption 2.0, safeguarding data against unauthorized access.
Samsung 990 EVO Plus MZ-V9S1T0 - SSD - 1 TB - PCIe 5.0 x2 (NVMe)
Solid state drive - internal
1 TB
Hardware Encryption
Encryption Algorithm
256-bit AES
NAND Flash Memory Type
Triple-level cell (TLC)
M.2 2280
PCIe 5.0 x2 (NVMe)
Intelligent TurboWrite Technology, Samsung V-NAND TLC Technology, Device Sleep support, Host Memory Buffer (HMB), TRIM support, Auto Garbage Collection Algorithm, S.M.A.R.T., IEEE 1667
22.15 mm x 80.15 mm x 2.38 mm
9 g
5-year warranty
1 TB
Hardware Encryption
256-bit AES
M.2 2280
PCIe 5.0 x2 (NVMe)
22.15 mm
80.15 mm
2.38 mm
9 g
Performance
Internal Data Rate
7150 MBps (read) / 6300 MBps (write)
Maximum 4KB Random Write
1350000 IOPS
Maximum 4KB Random Read
850000 IOPS
Reliability
MTBF
1.500.000 hours
Expansion & Connectivity
Compatible Bay
M.2 2280
Power Consumption
4.3 watt (read) , 4.2 watt (write) , 60 mW (standby) , 5 mW (sleep)
Software Included
Samsung Magician Software
Enclosure Material
Nickel coating
Limited warranty - 5 years / 600 TBW
70 °C
Shock Tolerance (non-operating)
1500 g @ 0.5 ms
Vibration Tolerance (non-operating)
20 g @ 20-2000 Hz
Capacity: 1TB
Capacity: 1TB
Brand: Samsung
