Samsung SP-H03 DLP WVGA Projector
Quicklinx: 75Z1WS00 Mfr#: SP0351VBX/EN
This pocket sized projector is light enough to take everywhere but still boasts some very powerful and impressive features. With an amazing ANSI 30 brightness, you'll get glowing reviews from everyone. The long-lasting, two hour battery gives you time to watch your favourite movie or put on a show-stopping presentation. And thanks to an external memory capacity of up to 16GB you'll have enough space for your presentations and extra multimedia files.
Samsung SP-H03 - DLP projector
DLP projector
Built-in Devices
Speaker
Brightness
30 lumens
Contrast Ratio
1000:1
Resolution
WVGA (854 x 480)
Native Aspect Ratio
16:9
Bulb type
LED
Bulb life cycle
Up to 30000 hour(s)
Video Input
RGB, composite video (NTSC, SECAM, PAL)
Speakers
Speaker(s) - integrated
7 cm x 7 cm x 2.8 cm
170 g
DLP projector
Built-in Devices
Speaker
Projector
Brightness
30 lumens
Contrast Ratio
1000:1
Image Size
22.9 cm - 203.2 cm
Projection Distance
0.35 m - 3 m
Resolution
WVGA (854 x 480)
Native Aspect Ratio
16:9
Bulb type
LED
Bulb life cycle
Up to 30000 hour(s)
OSD Languages
Thai, English, German, French, Italian, Portuguese, Swedish, Russian, Spanish, Dutch, Turkish, Chinese, Korean
Integrated de-interlacer (progressive scan)
Video Input
TV System
NTSC, SECAM, PAL
Analogue video Signal
Video Interfaces
VGA, composite video
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
1 Watt
1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x audio line-in - RCA x 2 , 1 x composite video input - RCA , 1 x USB
Carrying case
7 cm
7 cm
2.8 cm
170 g
Shipping Width
9.6 cm
Shipping Depth
9.6 cm
Shipping Height
22 cm
Shipping Weight
0.6 kg
Sound Emission
23 dB
