This pocket sized projector is light enough to take everywhere but still boasts some very powerful and impressive features. With an amazing ANSI 30 brightness, you'll get glowing reviews from everyone. The long-lasting, two hour battery gives you time to watch your favourite movie or put on a show-stopping presentation. And thanks to an external memory capacity of up to 16GB you'll have enough space for your presentations and extra multimedia files.
- Samsung SP-H03 - DLP projector
- DLP projector
- Built-in Devices
- Speaker
- Brightness
- 30 lumens
- Contrast Ratio
- 1000:1
- Resolution
- WVGA (854 x 480)
- Native Aspect Ratio
- 16:9
- Bulb type
- LED
- Bulb life cycle
- Up to 30000 hour(s)
- Video Input
- RGB, composite video (NTSC, SECAM, PAL)
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 7 cm x 7 cm x 2.8 cm
- 170 g
- DLP projector
- Built-in Devices
- Speaker
Projector
- Brightness
- 30 lumens
- Contrast Ratio
- 1000:1
- Image Size
- 22.9 cm - 203.2 cm
- Projection Distance
- 0.35 m - 3 m
- Resolution
- WVGA (854 x 480)
- 16:9
- Bulb type
- LED
- Bulb life cycle
- OSD Languages
- Thai, English, German, French, Italian, Portuguese, Swedish, Russian, Spanish, Dutch, Turkish, Chinese, Korean
- Integrated de-interlacer (progressive scan)
Video Input
- TV System
- NTSC, SECAM, PAL
- Analogue video Signal
- Video Interfaces
- VGA, composite video
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 1 Watt
- 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x audio line-in - RCA x 2 , 1 x composite video input - RCA , 1 x USB
- Included Accessories
- Carrying case
- Voltage Required
- 7 cm
- 7 cm
- 2.8 cm
- 170 g
- Shipping Width
- 9.6 cm
- Shipping Depth
- 9.6 cm
- Shipping Height
- 22 cm
- Shipping Weight
- 0.6 kg
- Sound Emission
- 23 dB
